Question about Garden
Battery wont stay charged
50" craftsman garden tractor battery will not charge when running if you jump it it will start and run fine untill you shut it off and then it will not start again unless you jump it
  • 218 Answers
Hi..my name is Keith..you can take the battery to like an AutoZone or AdvanceAuto..and they will test the battery for free..it sounds like it has a bad cell in it..also i would look at the battery cable connections to see if they are corroded and make sure the ground wire has a clean connection to the frame..if this didnt help..please write me back
Posted on Jul 01, 2009
Why would a person need to jump start a battery on a john deere stx 38 to start it,if the battery is good ?
You have indicated a bad battery. There is enough charge in the battery to start and run buy not enough when you engage the blades. Check the battery by load testing it and checking with a multi-meter.
Jul 12, 2014 | Craftsman Garden
Mower runs new battery down then wont start again unless jumped.
Sounds like you have a problem with a regulator. Hard to tell without knowing what model of mower you own. You must remember that whatever is attached to your battery charges it while the motor is running. If the battery does not receive that needed charge, running the motor will certainly drain your battery.
Apr 17, 2013 | Garden
Starts but shuts off after 10-15 min
Yes that is a shut off valve and im thinking either its a lose wire or it needs to be replace
Oct 03, 2012 | Craftsman 18.5 HP 42"
I have a craftsman with a kohler magnum 18hp. If i put a battery charger on my battery it dont charge i can turn the key and it wont roll over. If i jump my lawn mower and it running i can turn the key all...
Hi, if your battery wont charge you will need to replace it and when you do you need to check that the mower is charging by checking the battery voltage with a multimeter while the mower is running. It should be around 14 volts. Regards Phil.
Sep 06, 2012 | Craftsman Garden
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor will start when jumped but will shut off when jumper cables are removed
Sounds like there is no charge going to the battery. First check any fuses on the machine then try this if you can't get hold of a test meter to check input voltage to the battery, Remove and fully charge the battery, refit it and then start thr mower. It should run fine for quite a while till the charge gets too low to support your ignition system. If this works out, the problem is in the generator circuit and requires futher investigation.
Apr 12, 2010 | Craftsman Garden
Craftsman riding mower model 917.270921 put on a new battery still had to jumpstart got it running checked for charging 14volts to battery let it run for an hour runs pretty good but when i turn it off and...
What method are you jump starting? Are you putting clamps from jump battery on the posts of the battery or grounding the jump battery and then touching the + cable to the starter terminal?
Feb 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
WILL NOT CHARGE /CRAFTMAN LT 1000 17.5 OHV
You can jump off a off truck ,just dont have the truck running the
altnator can be to strong for the diodes in the tractors charging system (rectiforer).
Feb 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman mower 917 273201
Check the seat switch for the running problem. Disconnect the switch and jump the harness with a piece of wire, and see if the tractor stays running. If so, then the switch is bad. As for the charging problem. Test the voltage regulator. Start the tractor and put a volt meter across the battery. Red to red and black to black. Run the RPM to full throttle. You should have a reading of 14 to 14.5 volts. If not, the regulator is bad. Hope this helps.
Sep 21, 2008 | Garden
Garden Logo
251 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
