Question about Kyocera Office Equipment & Supplies
Black streaking accross the print even after i clean the glass
  • 143 Answers
Things to check.
Check the **** glass that the originals go across when using the doc. feeder. If it has even a spot, this will cause a streak.
Check the drum to see if the line is on the drum, if it is you may have a bad drum cleaning blade.
There is a corona cleaning device just above the drum that you can pull out and push in to clean the wire/comb. This too can cause a black streak.
Hope this helps
Posted on Jul 07, 2009
Black streak on scanned printed copies
Hi
Open your scanner lid and make sure their is no dirty marks sitting on your scanner glass. Also does this happen on the scanner glass or when using the ADF? If its on the ADF its most likely that the glass is dirty and needs to be cleaned. 6c66c542-b5d2-4d0a-8a21-00c054973a29.png
Apr 28, 2014 | Office Equipment & Supplies
Brother MFC 8500 print issue
Hi-
Try cleaning the glass part with a glass cleaner solution with a damp cloth, but if you need instruction how to clean the inside part of it, suggesting you consult a technician or certified servicer for the product to avoid further issue. thanks for using Fixya!
Jul 16, 2008 | Brother MFC-8500 All-In-One Laser Printer
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Dark black streaks accross copies
If the black lines are showing only when you are using the adf. Clean the adf slip glass with windex< the small **** of glass to the left of the copy board glass.
Aug 04, 2010 | Sharp MX-2300N Color Copier
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
Brother mfc. I made the mistake to use canned air to clean copier which got into my drum and made black streaks on my paper I keep cleaning the black streaks off the drum but when i put it back in i have...
First clean the glass of the laser.If you open the front door remove the drum from the machine just above were the drum was in place there is a glass mounted.Try and make a test print.If the streaks is still printing and you can see the streaks is deffinately from the drum you can strip the drum,clean the corrona wire and grit,and clean the drum brush.Strip only the drum unit if you sure the lines is caused by the drum.
Dec 11, 2009 | Office Equipment & Supplies
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Dell 962 prints fine - copies, scans and faxes are illegible
That is a sound approach you offer because, 1.) Cleaning the Carts. usually solves streaking, 2.) Cleaning the strip on the read glass fixes lines on the scanned images, 3.) You may have a saturation of ink inside the conveyance rollers that is soaking everything. You don't want to know how hard it is to get all the ink out of a wet printer. Replace it, save the hassle.
Jul 15, 2009 | Dell 924 All-in-One InkJet Printer
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
261 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
