Question about JVC HXD7 5-disc Home Stereo Theater System DVD changer Shelf System
Try pressing the channel up button multiple times to see if you can help the remote find the code. If you push the channel up button enough times and "something happens" then immediately press the mute button to save the code. It worked for my Sylvania tele.
Posted on Nov 14, 2007
0 characters
3 Points
Codes for JVC rm-sr558u universal remote control
Codes are stored in the remote. If you are using a JVC remote, no "programming" should be necessary.
Oct 17, 2015 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Model stvd 919 need remote control
if it's the jvc one i wouldn't bother, there just to slow but i would go on flea-bay to find one, you should be lucky there hope this helps, paul.
Mar 06, 2014 | The Singing Machine DVD/CDG Karaoke System...
JVC TH-V70 Shuts Down
Even after disconnecting the speakers, the systems shut down, means that there is something short inside the set. Normally, the output amplifier section circuits will have the short. The set need service, and may have to replace the audio output IC of audio secion. Contact the nearest JVC authorised service center at your town. OK.
Jan 24, 2012 | JVC MX-GC5 CD Shelf System
I lost my remote control, how do I get another one?
On the off-chance try e-bay... I had a miss functioning remote control on a kenwood home theatre system, searched everywhere for a replacement, then tried e-bay.. Chanced on someone who had found a remote control of the same model after selling their system (I was amazed by the coincidence), worth trying.
Aug 05, 2011 | Theater Research TR-502 5.1 Surround Sound...
Codes for innovage jumbo remote to use on Sharp and motorola cable box
here you go, have fun.
Dec 07, 2009 | Audio Shelf Systems
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
Optimus system 1030
after much trial and error i found a code that partially works.... 3025
it controls volume, power, mute and the c button on the remote controls the genre of music. AND THATS ALL. no analog of songs no fwd or rwd, its better than nothing though.
Apr 06, 2008 | Audio Shelf Systems
Onkyo DR-UN7 DVD Receiver remote control code
Nowdays there are CLONE type remotes available form electrical stores.
These clone type remotes carry all the codes necessary to work TV, Vdeos, CD players and other domestic sound systems.
I would suggest that you visit one of these stores and see what they have for your ONKYO system, the cost is not great and you will walk out with a complete remote for your system that will work all the other controls as well..
The stores have a fold out paper list, (thats very long) showing model and manufacturer detail for what codes you need to enter into the new remote to make it compatible wuith your ONKYO system.
Cheers From YUBEUT
Feb 11, 2008 | Audio Shelf Systems
Dvd player is locked
1/ Turn power off for a while at powerpoint for as long as you want 5mins should be fine then turn on and try again.(which youve probably done already) as well as looking up your model number on the net to attain a info on your system.
Does the remote still work if so try to find unlock in menu/setting/functions but if it requires a digit code then youll need the manual as it could have an override built for cases such as yours.
start at surround and find your model
good luck
Jan 28, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Jun 13, 2006 | JVC MX-DVA9 Shelf System
Audio Shelf Systems Logo
230 people viewed this question
Top JVC Audio Shelf Systems Experts
Are you a JVC Audio Shelf System Expert? Answer questions, earn points and help others
