Question about Samsung Washing Machines
Samsung washing machine error code te? - Samsung Washing Machines
  • 3 Answers
The problem could be the thermistor, but before you replace it, check the wiring. Many people with this error code have found one or more broken wires. If you call for service, be sure the technician checks the wires.
Posted on Dec 28, 2009
  • Marc Sanford
    Marc Sanford Oct 14, 2011
    IS there a way to get a wiring diagram for this unit? The owners manual is pretty pathetic for any real troubleshooting.
  • netchiefst
    netchiefst Aug 06, 2012
    The wires for mine were Right of the tub drain hose directly behind the thermistor. The wires fell out of the connector and were damaged by fatigue. It would have required an entire harness but I stripped the ends and reconnected them the old fashioned way.
    Genius:
  • 1,847 Answers
TE says it's a CONTROL ERROR and the solution is to unplug machine and call for service. Hope that helps.Thanks.
Posted on Jul 01, 2009
SOURCE: samsung b1245s washing machine
Error code is actually 5e and is to do with your drainage being blocked. Check the flap in the lower right of the machine. Open and unscrew the big black wheel/cog thingy (make sure you get lots of towels or drain all the water first with the little pipe to the right of the big black wheel/gog). I found a few coins trapped in my pipe and its working a treat now I cleared them out and spent them on lots of sweeties. Yummy. :D
Posted on Aug 19, 2008
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 311 Answers
SOURCE: malfunction code tE
TE error code stands for thermistor error. You have to remove the front panel and ohm out the heating element. If you have continuity most likely it will be fine. There is a thermistor located next to the heating element that will probably need to be replaced. LG's are the only machine besides GE ref's that I have ever seen thermistors go bad on. There is probably an ohm reading you should get through the thermistor but unless you have an analog meter or a fluke most standard digitals wont read into mega-ohms. Removing the front panel is model specific. But i can tell you the spring around the front boot (drum gasket) needs to be removed and there will be some hidden screws at the bottom by the pump where the access panel is located.
Hope this helps _MJ_
Posted on Jan 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
richroth
  • 9472 Answers
SOURCE: I have a samsung washing
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Posted on Dec 11, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Error code tE
    if you replaced the thermister
    and tE comes up
    then its the heating element has failed
    and or its thermal safety fuse set up perhaps failed also
    Apr 28, 2015 | Washing Machines
    Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
    A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
    1. Unplug the washer from the power outlet for 10 seconds.
    2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
    3. Once the washer has drained, restart the wash cycle.
    4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
    Apr 06, 2015 | LG Washing Machines
    What does the code te on the LG Tromm washing machine mean?
    The TE error or fault code is to indicate a defective water temperature sensing thermistor. The thermistor cannot be repaired and will have to be replaced.
    Sep 07, 2014 | LG Washing Machines
    I'm getting error code tE on samsung silvercare WF316LAS/XAA
    tE is mostly related to
    temperature sensor wire and connection problem. Look for a broken or loose wire.
    Dec 07, 2012 | Washing Machines
    Displays 'tE'
    Hi
    'tE' is a Thermistor Error.
    Here is what the manual says:
    This error occurs when the Thermistor circuit is abnormal or a voltage of O.2v or below or, 4.5v and over is detected. This error can be cleared by POWER switch OFF.
    Unplug the machine from the wall for a few seconds and restart.
    Ash
    Sep 18, 2011 | Samsung Washing Machines
    Getting a "te" error code -- a heating issue?
    I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
    Jan 05, 2011 | LG WM2487H Front Load Washer
    Washing machine error code is tE, something to do with the power?
    tE stands for Thermistor Error. This is a problem having to to with the water temperature, possible causes are: water heater was low on hot water, or the thermistor gave a faulty reading. It can be corrected by unplugging the machine for 10 minutes and restarting the machine.
    If this helps you please rate my solution.
    Thanks, Repairman45
    Dec 02, 2010 | Samsung Washing Machines
    Washing Machines Logo
    3,809 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
