Question about Canon DR-7580
In need of a service / parts manual for Canon DR 7580 scanner
  • 490 Answers
You can get spares from http://www.scannerparts.biz/servlet/StoreFront
Service Manauals are little difficult to get, need to search the web patiently. Be sure of the site, there are quite a false sites that rob you of your credit card details. S. Mohan
Posted on Jul 20, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: canon dr-7580 scanner how to initialize cis
Hi, You may need to calibrate a new CIS with new Assembly. Later on this new assembly can be removed and your old one will do. Assembly means solonoid+ shading sheet. This will work for sure Samir Dhingra 9820800633
Posted on Jun 05, 2010
Capture barcode at scanner Canon Dr 9080C
You will need to purchase the CD "Canon Barcode Module III" and install it on your computer: Mfg. Part: 1922B001
Then you can select it in Canon's document scanning software/Capture Perfect.
Scan-R-Store
Dec 10, 2013 | Canon DR-7580
How to reset counter on canon dr 7580
You need to run Qumatool to reset the counter
S. Mohan
Oct 14, 2011 | Canon DR-7580
Need the part number for the scanner led array? getting lines on scans not all led's are turning on and just need to order the new array. Its the upper array on the canon scanner dr 7580
MG1-3616 is the part number for the entire reading unit. I am not aware if only the LEDs are available separately. It is very unlikely that only some LEDs are working. Ensure glass is clean.
S. Mohan, Chennai, India
Feb 17, 2011 | Canon DR-7580
Canon dr 7580 error code E30
E30 is a Error related to Exhaust Fan. Pls check if the Fan is working, replace if required. If the scanner was used in a dusty environment, the dust can clog the free movement of the blades. It may require cleaning.
Nov 18, 2010 | Canon DR-7580
Canon scanner dr7580 not working. E32
As per Service manual , E32 is "Wrong installation of main CPU PCB (The CPU PCB for a DR-9080C has been installed in a DR-6080 or vice versa.)"
Oct 06, 2010 | Canon DR-7580
Canon dr-7580 error 32
According to the service manual if 6080 and 9080c cpu/motherboard are interchanged this appears.
Oct 05, 2010 | Canon DR-7580
Canon dr-7580 scanner how to initialize cis
If the Black lines are jaggered and are vary in size with different levels of brightness, then most likely it is scratch on the glass. If the lines are sharp and perfect and does not change when different brightness is chosen, then it could be failure of CIS module (Try this under B&W mode). To the best of my knowledge there is no concept of initialising the CIS, you may need to clean the Shading sheet.
Apr 10, 2010 | Canon DR-7580
CANON DR 7580 SCANNER : SCANNED IMAGE HAS A LIGHT STREAK DOWN THE CENTER. LOOKS LIKE THE IMAGE IS FADED APPROX INCH WIDE RUNNING VERTICAL. DOESN'T HAPPEN ON EVERY IMAGE
Assuming the document going through the scanner looks normal, there are a few things to check. If you open Capture Perfect, you can adjust the contrast and brightness as well as the thresholds. Sometimes different toners react differently to the scanner...paper is a big thing too. Multi-part forms can be tricky to get the settings adjusted so you pick up enough of the text but not that on the other side. If it's still messing up, you can try and get it serviced. Ikon is nationwide and can help out.
Apr 24, 2009 | Canon DR-7580
Bar Code Used as Document Name
It's not really an issue with the scanner. The scanner will pick up the image and convert it to whatever you want, but your backend software is what you'll need to mess with for this. Any form recognition software will work (Form Storm, ABBYY FormReader, etc.)
Dec 27, 2007 | Canon DR-7580
443 people viewed this question
old marine
old marine
