Question about Sony Video Cameras
Unable to select the white balence fearture
When filming outside in bright areas, the image becomes bleached out. in the menu section i am unable to select the white balence feature to try fix the problem. how can i overcome this?
  • 72 Answers
Dear ...u need to rate me for this ok ....
actually i want to ask u that when you are doing white balance is your camcorder in recording mode ?
if, yes then dear camcorder will not take white balance in recording mode .. make itin stand by mode and then do white balance by keeping a white paper in front of the camcorder at least two meter away ok.
Posted on Jul 01, 2009
I am new to gimp and most of the instructions I have found on YouTube do not give enough detail or move too fast to follow. I need to clean up the white background of a scanned black & white line...
There is various ways to achieve this.
The quickest way is just to adjust the levels - Go to the menu marked IMAGE then hover over ADJUSTMENTS and to the right should be another menu, containing various options such as LEVELS and CURVES
The easiest option is probably altering the BRIGHTNESS-CONTRAST. (Just up the contrast and up the brightness slowly and you should be able to see the impact on the image). More complex/precise options are available with LEVELS and CURVES. Both are pretty self-explanatory - just play around with the arrows on LEVELS and you will see the image alter. Or on curves, just click on the curve and drag to change the shape/add points.
For high precision, the simplest would be to select a paintbrush from the toolbox and the colour white and just paint over the areas you don't need.
Jan 04, 2011 | GIMP GNU Image Manipulation Program
When taking pictures outside bright white photos
i am an train picture guy but neverthe less u cant take anything for granted put cam on "P" and see whad happens and check your manual
Aug 24, 2009 | Olympus FE-220 Digital Camera
Bright picture on outside images
try to change the preset setting on film maybe its is set on presentation which gives you more light than in film mode
Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
Samsung digimax i5
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
White balence
The EOS Rebel K2 is a film camera. White balance settings on digital cameras are an electronic 'adjustment' to the image sensor. In film cameras, the film is the image sensor. So white balance is dependent partially on the film you're using, but more often on the filters you add to the lens to correct for various lighting conditions and light sources.
Jun 13, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Menu and select OK to activate it. Once Pixel Mapping is completed the Menu displays. The bright dot should no longer appear in your downloaded images.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Mode Menu and select OK to activate it. Once Pixel Mapping is completed the Mode Menu displays. The bright dot should no longer appear in your downloaded images.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's menu and select OK to activate it. Once Pixel Mapping is completed the Menu displays. The bright dot should no longer appear in your downloaded images.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Small bright dot
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Small bright dot
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Video Cameras Logo
102 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
