Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher & Paykel washer puddles water during spin cycle. Appears to be splashing over the tub and hitting the lid and dripping down the sides. Tried rebalancing with no luck.
If you only have water splashing out during the spin it is the diverter valve that needs cleaned out or replaced.
Posted on Jul 06, 2009
Splashing water during spin cycle
Failure of the water level sensor
Oct 10, 2017 | Fisher Paykel EcoSmart GWL15
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher paykel eco which is spining water on the floor.
You could take the pump out and check it for obstacles
Mar 05, 2010 | Washing Machines
During the rinse and spin cycle, water is sprayed everwhere
There may be too much water and not enough clothes in the washer. If that is the case the water rises up the side of the tub when spinning and overflows the inner tub. Usually it goes into the outer tub but it can spurt out through bleach dispenser and run down the inside of the cabinet or hit the lid and splash out. Set water level (Xsmall, small, medium, large, Xlarge) appropriate for amount of clothes.
Aug 11, 2009 | Washing Machines
Fisher Paykel Ecosmart washing machine spills water.
sometimes too much detergent, or extra cleaners like oxy clean) will cause lots of foam which will cause the water level sensor to misread, or foam over the top of the drum. if this is not the problem, you will have to tilt the machine on its side and look for loose or damaged hoses. the play in the tub will not cause leaking
Jul 10, 2009 | Washing Machines
I have a 1.5 yr old Fisher Paykel ecosmart washing machine. During the past 2 loads there has been a notable water leak (significant puddling on the floor). I haven't witnessed the problem, but there is...
the play in the tub in normal, it sounds like you have an over sudsing issue, run an empty load with 3 cups of vinager in the tub, set the water temp to hot, cut way down on soap, if you use liquid dont even fill the cup 1/3 of the way, I know this sounds dumb but try it, I have one and this happened to me
Jul 10, 2009 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
352 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
