Question about Dell E152FP 15" Flat Panel LCD Monitor
I turn the monitor on, then it turns itself off.
When I turn on the monitor, it will turn off. I have to repeat this process a number of times until it will stay on. And over the course of time the number of times I have to do this has increased. Today it took about an hour for it to finally stay on. This is beyond frustrating.
  • 436 Answers
It may be the problem with the power on/off switch.The problem can be solved by replacing it.Contact you authorised technician..
Posted on Jul 01, 2009
How to reset security code
  • Select a five-digit number and record it in the manual or some place else easily accessible in case you forget it.
  • With an assigned fob present, turn the "IGN" key in this pattern:
    Ignition-Off-Ignition-Off-Ignition.
  • Press the left turn signal three times.
  • Press the right turn signal one time and release. The turn signal should flash three times. The current PIN number should appear in the odometer. The first digit will be flashing.
  • Enter the first number by pressing the left turn signal the same number of times as the digit. So if the first number is 5, press the left turn signal five times.
  • Press the right turn signal one time and release. The new number will replace the old number in the odometer.
  • Repeat steps 5 and 6 until all numbers have been reset.
  • Turn the ignition key to "Off."
DISARMING WITH YOUR PIN
  • Turn the key to "Ignition."
  • Hold both turn signal switches until you receive confirmation.
  • Press the right turn signal once.
  • Repeat steps 3 and 4 until you have entered your PIN.
Oct 11, 2013 | 2007 Harley Davidson XL 883 Sportster
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    I turn my Dell computer on and in 10 maybe to 20 minutes my computer monitor goes black and the light turns to standby but my computer is still on. also i hear what ever sound was going on before the...
    Check your cpu fan if it`s working and also check your power option it`s given in the control panel otherwise it might be problem with your monitor or vga card.
    Jul 19, 2011 | Computers & Internet
    I have a sony tv, model number KDF60WF655... i turn the tv on and it turns on for about 1 min then turns off, the green light flashes several times then turns itself on again. the process keeps repeating...
    Replace lamp in tv as this symptom shows existing lamp is near to end of its working hours life span and need to be replaced.
    Lamp replacement procedure is easy and would be written in user manual.
    Buy Sony original lamp for good picture in tv.
    Thanks.
    Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
    Samsung Syncmaster 204T flashing
    Please check that all the cables are plugged in firmly on the back of the monitor and on the back of the computer.
    However....
    It sounds like the back light on the screen is faulty. If this is the case it is definitely a return for repair problem. You should be able to find the warrantly procedure for your area on the samsung website.
    Cheers
    Dave
    Jun 21, 2009 | Samsung 204T 20" LCD Monitor
    Compaq Presario F700 keeps turning on and off
    At this point I assume you've tried to go into SAFE mode, and into BIOS with no luck. You're right about the overheating but I think the damage is done. If the unit will no longer stay on in any mode or condition then heat has ruined something. First easiest part to check is memory. The check the CPU (most laptops still have a plug in CPU). If neither of these are suspect then take everything off the motherboard, including the screen (I use and external monitor). If the problem still exists then it's time to use a scope.
    May 30, 2009 | HP Compaq Presario F730US Notebook
    Montior Repeatedly Shuts Off/Goes Black
    i have the same problem .
    already know what it is .
    its the cfl power inverters which are build into the power supply
    easy way to see is let the computer start up hold a flashlight up to the screen you should see your desktop .if so its the inverters/powersupply .
    just started looking for a replacment for mine the closest i have found is around 25 bucks plus shipping wont know if it will work till monday when i can call them to match up the one i have
    Jan 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
    Monitor will not turn off and keeps flashing the words Auto processing
    it is not a bad rom. if it was a rom it would constantly act up but it only acts up upon overheating. The solution is difficult but if you open the monitor you can find all of the heatsinks take them of and replace them with bigger ones. or have a fan blowing on it at all time it is active i added bigger heatsinks to my emachine le1799 and it solved this problem of pulling up menu and changing setting by itself and the lack of the ability to turn power of.
    Sep 15, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
    Dell E152FP 15" Flat Panel LCD Monitor Logo
    144 people viewed this question
    Alun Cox
    mukhtar21 shaikh
    mukhtar21 shaikh
