Question about Amana 19 cu ft Bottom Mount Refrigerator, ABB1921DE
My refrigerator is 4.5 years old and the problem is that the freezer has ice build up in a matter of days, so much that it prevents air flow from the freezer below to the fridge above. I have defrosted it a couple of times but it builds again in a matter of days
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 01, 2009
Refrigerator/freezer stopped cooling/freezing yesterday. Lights are on inside and 8 hear the fan running in the freezer but no cold air. Tried powering off and also unplugging to see if it would reset...
possible failure of defrost mechanism causing ice to build up behind back of freezer preventing air flow into freezer and fridge. Try turning it off for enough time for ice to melt if cause.
if this is issue the repair man will need the ice half melted to be able to test the thermistor that senses the ice buildup.
Nov 06, 2017 | KitchenAid KSCS25FKSS Side by Side...
I have a Frigidaire Model FRS6R5ESBF that is 3 years old but did not get installed until 4 months ago. The freezer appears to be working fine but the refrigerator side is getting warmer by the day. It...
Could be that the freezer is icing up stopping the air flow coming up into your fridge, try switching it off for at least 12 hours with the freezer door open.
Nov 02, 2010 | Frigidaire Refrigerators
My Whirlpool refrigerator builds up ice in the freezer around where the cold air comes from. Eventually it starts to fill the bottom of the freezer with clear ice. It has done this almost from since it was...
you should manually defrost fridge/freezers every 6 months for optimum performance.also fill any spare capacity with clean waste foam, cuts down on all that cold air dropping the floor/warm air filling void (i put foam in plastic bags. works for me
Feb 08, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Side by side refrigerator will not cool and ice maker does not work although the freezer is cooling. It is 5 years old.
check damper operations. blockage of air flow. check make sure no ice build up in back panel of freezer side like a snow pattern
Feb 07, 2010 | Refrigerators
Frig too warm, freezer too cold
if there is ice build up you have a defrost problem. either the heater bimetal thermostat timer or evap fan could be bad. you could also have a stopped up drain. if the coils get too much ice build up the air wont beable to travel through them and the bad air flow will cause the fridge to become warmer
Sep 16, 2009 | Frigidaire FRT8S6EMB Top Freezer...
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Mar 04, 2008 | Kenmore 64823 Top Freezer Refrigerator
Fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
GE Fridge/Freezer Having to turn temp up just to keep it cold
That's a typical sign of the defrost cycle not working and ice is building up on the coils. That prevents proper air flow of cold air around the compartments. As ice builds up you get less air flow and things warm up soooo you turn up the cold which causes more ice to build up and even less air flow soooo you turn up the cold. See where I'm going with this? You'll have to check your defrost timer, defrost t-stat and even the heat element. Look in your owners manual or online for diagrams of where the parts are located on your older unit, then go from there.
Dec 30, 2006 | GE GTH18KBR Top Freezer Refrigerator
Amana 19 cu ft Bottom Mount Refrigerator, ABB1921DE Logo
138 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
