Usually, it means that the timer function has been turned on, and the camera is going through a countdown to trigger the shutter.
After that, it means that something else is not working correctly. If video works and records, then you know that the sensor and memory are functioning correctly. At that point, check to see whether your camera and lens are set for the form of autofocus or manual focus you want and that the aperture is still functioning correctly.
At some point, switch the camera to an all manual settings mode and try the shutter switch. If it still does not take a picture, the switch may have a problem.
SOURCE: Canon Digital Rebel XT / EOS
In the communications option of the camera Menu, there are two options to choose from. Try changing the options. one of them works with Canon software to download images.
SOURCE: Canon SD 550 does not work when flash setting is ON
I have the same problem. Cannon customer support says it will fix this for $119 + 8 for shipping... or you can get a refurbished SD 800is for $140+10 for shipping with w/ a 6 month warranty... what a deal ;~)
SOURCE: Cannon Powershot SD 870
you can change it to no flash by when your taking a picture press the right arrow
SOURCE: I'm trying to transfer my pictures from the camera
Could it be the camera battery is depleted?
SOURCE: Canon lens locks when taking a picture.
Mirror lockup is probably enabled. You can disable it by going into Menu and then Custom Functions. Select Mirror lockup and disable it.
