The paper light continues to flash and it won't pick up paper to print.
  • 744 Answers
Hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..
or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Posted on Jul 01, 2009
Hp officejet 4500 will not print from mac ibook g4
HP Officejet 4500 (G510) Series and 4500 (K710) Series All-in-One Printers - The All-in-One Does Not Pick Up or Feed Paper Issue The product does not pick up or feed paper from the paper tray. How to use the solutions in this document To resolve the issue, try each solution in this document in the order presented. c01733891.gif IMPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware is functioning correctly. To print a self-test report, use the steps in the following table. How to print a self-test report
  1. Load plain, white paper in the paper tray.
  2. Press and hold the Cancel button (c01235250.gif ) on the product control panel.
  3. While holding the Cancel button (c01235250.gif ), press the OK button (c01961874.gif ). The self-test report prints.
NOTE: Refer back to the steps in this table after attempting each solution. Solution one: Reset the All-in-One
  1. Disconnect the power cord from the back of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the back of the product.
  4. Press the Power button (c01602202.gif ) to turn on the product.
  5. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the test page prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the test page does not print , continue with the next solution.
Solution two: Check the paper The condition of the paper or the amount of paper loaded might prevent the rollers from picking it up and feeding it through the product. Use the following steps to check the paper in the input tray.
  1. Remove any wrinkled or damaged paper from the input tray.
  2. Make sure that all the paper is the same size and type.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper contains from 10 to 25 sheets of paper.
    NOTE: Do not overload the input tray. Make sure the stack of paper is shorter than the top of the paper width guide.
  5. Insert the stack of paper into the product, and then gently push the paper width guide snugly against the paper. Figure 1: Load paper c01970609.gif 1 - Load paper 2 - Adjust the paper width guide Illustration of loading paper and adjusting the paper width guide
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution three: Check the print settings The paper settings in the print driver must match the paper size and type loaded in the product. Use the following instructions to adjust the paper settings.
  1. In the software program you are printing from, click File .
  2. Click Print , and then click Setup , Properties , or Preferences .
    NOTE: The specific options might vary depending on the software program.
  3. Click the Features tab.
  4. In the Basic Options pane, select More from the Paper sizes drop-down list.
  5. Select the size of paper loaded in the product, and then click OK .
  6. In the Basic Options pane, select More from the Paper type drop-down list.
  7. Select the type of paper that you loaded, and then click OK .
    NOTE: These changes do not change the default print settings. The print settings revert to the default settings the next time you open the program.
  8. Change any other print settings necessary, and then click OK .
  9. Click OK to print.
  10. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution four: Clean the rollers Follow these steps to clean the rear rollers and the pick rollers on the HP product. Step One: Clean the rear rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 2: Remove the rear access door c01961876.gif Remove the rear access door
  4. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the paper rollers. Rotate the rollers with your fingers to clean all the way around. Figure 3: Clean the rollers c00246512.jpg Graphic: Showing paper rollers
  5. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely. Figure 4: Access door rollers c01590938.gif Access door rollers
  6. Allow the rollers to dry completely.
  7. Reattach the rear access door. Push the door forward until it snaps into place.
Step two: Clean the pick roller
  1. Remove any paper from the paper tray.
  2. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 5: Remove the rear access door c01961876.gif Remove the rear access door Figure 6: Rear rollers and location of pick roller c01976220.gif Image: Rear rollers and location of pick roller
  3. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the pick roller. Rotate the pick roller upward with your fingers to clean all the way around. Figure 7: Pick roller c01975068.gif Image: Pick roller in the product
  4. Make sure that the pick roller and the rollers around it are clean, free of paper bits, and rotate freely.
  5. Allow the pick roller to dry completely.
  6. Reattach the rear access door. Push the door forward until it snaps into place.
  7. Load the tray with plain white paper.
  8. Reconnect the power cord to the rear of the product.
  9. Press the Power button (c01602202.gif ) to turn on the product.
Solution five: Service the All-in-One
Mar 06, 2013 | HP Officejet 4500 All-in-One Printer G510G
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
Hp2200D Won't print - "jam" light comes on - but no jam
Have you cleaned the feed roller? If it's dirty it'll spin but won't pick up any paper. Look at the paper after a "jam." Can you see any black roller marks on it? That's a sure sign of a dirty roller. If you suspect a dirty roller, clean it with a little alcohol on a cloth.
Mar 10, 2009 | HP LaserJet 2200D Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Not printing
There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
Thoroughly check the paper feed path.
If not working, then check/clean the rollers.
Jan 20, 2008 | Kyocera FS-720 Laser Printer
16 people viewed this question
k24674
jasbo
jasbo
