Question about Onkyo TX-DS575 Receiver
Bose Acoustimass power
Hi there
I have a early model Bose system consisting of left and right cube speakers and an Acoustimass Sub module providing power to both the sub and the speakers.
When I turn the stereo on it works fine, but after 20 seconds all sound cuts out, the control unit is still going and I can hear through the headphones but not through the speakers. I turn the sub off and turn it back on and it lasts for about 10 seconds, retry then 5 seconds. Until it doesn’t work at all.
I live in New Zealand and we have one bose supplier in out main city, which is a $300 trip or $150 courier without even getting it looked at.
Any help would be greatly appreciated, thank you in advance.
  • 752 Answers
The amp is overheating. Disconnect one speaker at a time to see if problem persists. If so, the amp needs serviced.
Posted on Dec 18, 2007
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
Dead Bose acoustimass bass module
Even i have the same problem.bose does not providing a single sub-woofer
Feb 20, 2010 | Bose Acoustimass 15 System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
How do I connect my Acoustimass® 5 Series III Stereo Speaker System to my Onkyo SR506 av receiver?
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
Oct 28, 2009 | Bose Acoustimass 5 III System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Bose AM-500 Acoustimass Bass module hookup to new Sony STR-DG910 Receiver
it need it own sub out speaicl done so bye bose steyem crossovers wont work right in your set up nee dto upgrade the sub try mtx
Feb 04, 2008 | Audio Players & Recorders
I have the same problem TOO!#$#@% Anyone out there?
Nov 08, 2007 | Bose Acoustimass 5 III System
Onkyo TX-DS575 Receiver Logo
239 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
