Question about CMB T43 750 Notebook
My laptop freezes with jagged diag lines showing on the monitor
I'm running an Acer Aspire 5520 laptop and it just recently started to freeze up with the monitor showing only diagonal jagged lines mostly gray but some are colored. I have to hold the power button to shut down and reboot. I sometimes have to do this twice to restore it, What can be causing this? THANKS!
  • pann422 Jul 03, 2009
    Thank you. I did that but won't know if it works for a week or so as the problem wasn't daily. Thanks again.
  • 197 Answers
Try to re-install your video driver to its latest version.
Posted on Jul 02, 2009
Have a acer aspire 5520,it has developed several problems,1, will often freeze on full screen mode,have to shut it down and restart,2, will keep on shutting down after battery light starts flashing,will...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Acer Aspire 5520-5908 Notebook
After about 5-8 minutes everything freezes, mouse, can't even use ctrl,alt delete, what to do? Do I have a virus?
Are you using vista? If so beware MS updates. Also keep a close eye on the temp. of your laptop. That model Acer aspire 5520, is known to have an overheating problem and /or cold solder joints on the motherboard under cpu block and the video chip. I can't say if you do or don't have a virus, but if when you turn on, and the laptop starts cycling thru on, then off non stop, you will need to research reflowing solder with that model. I have repaired 2 units with that issue.Run malware bytes antimalware, SuperAntiSpyware and Spybot S & D and see what they say.
Jul 10, 2010 | Acer Aspire 5520-5908 Notebook
Screen freezes and shows crazy purple colors in the screen or pink horizontal lines. The one time it shuts itself down, the other i have to use the on/off button to shut it down. When restarting it gives...
Incedible in one web page I found this solution and its work for me, the problem is the batery, just remove and no more frezee screnss and horizontal lines in color purple, Hope this helpt to you.
Oct 26, 2009 | Acer Aspire 5520-5908 Notebook
Laptop freezing acer aspire 5520
If you are carrying it around, and you are getting black lines across the screen, you have a lot more than thermal pads to be concerned with. The connections inside are breaking down and arcing. (That's what the ssszzzzzzzZZZTTT noise is).. Unless you are good at repairing printed circuit boards, you should take it to a repair shop.
Sep 17, 2009 | CMB T43 750 Notebook
Acer Aspire one 205 freezes after re-booting
Do you mean the desktop is shown and then it freezes-meaning the things (folders etc) doesn't load? If so, you can try the CTRL+SHIFT+ESC button to show task manager where u can open run and type explorer to show the desktop folders and icons. But, this is caused by virus so be sure to clear it off.
Jul 21, 2009 | Acer AOA150-1690 Aspire Notebook
ACER Atheros 802.11bg Wireless
can you get on in safemode
if you can go to device manager and see if network driver shows then click and update
then do a disk defrag form safemode
please let me know
Feb 13, 2009 | Acer Aspire 5520-5908 Notebook
Windows stop
start in safemode and then check drivers in device managerupdate monitor driver and
update video driver.Then do a disk defrag
restart and let me know what happens
it just might be the video card
also have you added any new memory
Feb 12, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire cooling fan
Thanks for the reply. my problem is with my computer its an acer aspire 5520. whenever im using it and the fan or the motor starts the screen freezes and you cant do anything.what are the hing that i can do to improve it. thanks again.
Aug 29, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5520-5334
press insert usually solves the problem
Jul 13, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
394 people viewed this question
Top CMB Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
