Question about Nikon Speedlight SB-800 TTL Flash
Flash only works in manual and is always flashes at full power!
I noticed after a few months that it did not work in TTL, iTTL, AA etc.
it seems to be firing after or before the shutter, either way the picture is always black. I've tried resetting it and nothing seems to work. only in manual mode does it fire in sync, but I can't adjust the power. from 1/1 to 1/128 the output is exactly the same. I had to buy another SB600 to get anything done.
  • 24 Answers
This needs a good check. If you are in India, I can help you.
Posted on Sep 07, 2009
I have dark pictures even with sb600 flash working. Anybody have suggestions? Is it my camera settings? I use iTTL and I think flash is not enough
I don't know what camera you have and I don't know which mode you are using (manual exposure, full auto, shutter or aperture priority, etc.) so I can only make a generalized guess. It may be related to your shutter speed. Although your camera may have a wide range, for example 10 to 1/2000 second, your flash will only be properly triggered and synced over a limited range. I would take a few pictures with the shutter at 1/60 second and see if that helps. Also, on more advanced SLR's you can select a rear curtain mode. See if that may be a factor.
Oct 23, 2011 | Nikon Speedlight SB-600 TTL Flash
DOES IT WORK WITH NIKON D300S
Yes, though it's an older flash unit and cannot be used in the iTTL mode. The "Other Flash Units" section of the D300s manual (page 350 in my copy) lists the modes in which the flash may be used. Another concern is that the flash may not work well with certain lenses. The "Usable lenses and cameras" section of the SB-29 manual (page 5) discusses this.
If you need manual, you can download the D300s manual from
http://support.nikontech.com/app/answers/detail/a_id/16525/kw/D300S/r_id/116678
and the SB-29 manual from
http://butkus.org/chinon/nikon/nikon_sb_flashes/nikon_sb_flashes.htm
Jun 25, 2011 | Nikon Macro Speedlight SB-29 TTL Ring...
Nikon d90 and spidlight sb 22 TTL not working can that spidlight be yuset on d90 or not
this flash will not work on the newer digital nikon cameras, the flash for d90 needs to be ittl compatible.
Jan 12, 2011 | Nikon Speedlight SB-22S TTL Flash
Running in TTL mode with Nikon D200, flash EF-500 DG ST NAd, doesn't work. In manual mode everything runs well.
this flash is not compatible with the d200. i had one and sent it back to sigma, they upgraded the software in the flash for free. now it works in all modes, it needs to be iTTL to work on the nikon d200 the NAd version is not iTTL.
Jan 01, 2011 | Sigma EF-500 DG ST for Nikon Flash
Sigma ef-500 dg st won't work with my d300 or 200 in ttl mode
This Sigma flash is not Ittl compatible. The D300 and D200 Nikon must have Ittl compatible flash to operate in any of the Automatic modes. It is a great flash but will not work on those two cameras.
Dec 14, 2010 | Sigma EF-500 DG ST for Nikon Flash
My nissin di466 block my Canon 450D. After couple shots or sometimes after 20-30 shots with nisin attached and turned on on my Canon, the camera block, I can not take a picture the AF did not work. Turning...
my Nissin Di466 had all the lights playing up at the back with nothing really working. I took out the batteries to find one had leaked. have know cleaned it up with it turning on ok, but dose not work on camera through ttl. Will not flash when shutter pressed.
Oct 01, 2010 | Nissin DI466 Power Zoom Speedlite Nikon...
I changed the batteries and continued to take photos when i noticed that the screen was flashing on and off and then going to standby mode. tried resetting back to default but screen still flashes. flash...
Hi Bill,
You are not using this flash like a sub-machine gun, right?
Is your reachargeable batteries older than 15 months?
Try this:
Set to low power on flash, set flash to manual.
Remove flash from hotshoe.
Fire the flash by pushing the flash button for 3 mins, same problem(s)?
atdlee@netzero.com
Jan 17, 2010 | Nikon Speedlight SB-600 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-800 TTL Flash Logo
    227 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
