2005 Nissan Pathfinder Logo
A
Anonymous Posted on Aug 17, 2014
Free nissan repair manual
3 warning lights on . vdc, slip and check engine. car hard to start.what cani do?
A
Anonymous
Buy the Factory CD or Print Service Manual
Free-- won't be your vehicle-- or any good to you
  • Anonymous Aug 18, 2014
    Also going to need professional scan tool to access the modules
5 Related Answers
Anonymous
  • 321 Answers
  • Posted on Aug 09, 2008
SOURCE: TCS/SLIP & Check Engine Light Warning
TCS is Traction Control System,and all TCS's are controlled though the Anti Lock Braking (ABS) system.Here's how it works:Each wheel,or in some cases,only the drive wheels have a speed sensor mounted near the hub or axle,and sends a speed signal to the PCM (Powertrain Control Module).The PCM monitors wheel speed continuously,and if it sees a speed out of the ordinary,say for example the right rear tire is spinning and traveling at a much higher speed than the left rear,the PCM will pulse the brakes through the ABS system on the right rear to slow down the right rear so that the left and right wheel speeds match up,this is how the traction control works.So,if you have a TCS problem,the PCM will see this and set a Dignostic Trouble Code (DTC).You need to pull the DTC's out of the system with a scan tool,diagnose and repair the DTC's.It could likely be something as simple as a malfunctioning wheel speed sensor,but you won't know until the codes are pulled out,as this will point in the general direction.Good luck.
hillbillytra
  • 26 Answers
  • Posted on Dec 29, 2008
SOURCE: Nissan sentra 1993 1.6 l won't start
try puting shifter in nuetral , common nissan problem
Anonymous
  • 40 Answers
  • Posted on Apr 04, 2009
SOURCE: transmission slips 2000 nissan maxima
From what you have described it sounds like the transmission control solenoid pack is hanging up and needs to be replaced.
When you shut the car off it resets the position of the soleniod allowing it to work for a while before it gets hung up again.
Overtime turning it off and back on again won't anymore.
Are you sure the solenoids were new and installed correctly?
Sometimes the replacments you buy are of a worse quality. Their probably is another issue causing your soleniods to wear faster than they are supposed to and when you install inferior quality replacments they may just wear out quicker. I'm not saying this your problem just an idea.
If you haven't changed the fluid and filter in a while then that definetly would be the next thing I would do before anything else.
You can check your fluid to see if its dark and smells burned or if its clean and lighter colored.
I really hope this gets you headed in the right direction and good luck.
If you feel I've helped in any way please give me a fixya rating,
AadoubleA
Anonymous
  • 28 Answers
  • Posted on Apr 12, 2009
SOURCE: 2000 NISSAN MAXIMA TRANSMISSION SLIPPING
If you havent already try to change the transmission filter.Sometimes when the filter gets dirty fluid pressure is comprimised and certain pumps and solenoids which control shifting inside the transmission function off of the fluid pressure,
seanpwright
Sean Wright
  • 2045 Answers
  • Posted on Sep 15, 2009
SOURCE: Loss of Power, VDC light and Slip light comes on
Have ther codes checked that are making the engine light come on first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
2answers
Hi I have a Nissan Maxima 2007 last night my car stalled then the VDC off then slip light came on why did this happen and can I still safely drive my car.
NO, its NOT SAFE TO DRIVE. Your car may loose power in the middle of the intersection and then what? VDC and Slip light may be related to ABS system, please have it check.
What does Brake light,VDC light and slip lights on . This happened when brake pedal pulsates,but I do have brake pedal.
See if the following information helpful:
1. Keep an eye on the dashboard for the indicators marked "SLIP" and "VDC Off" which will tell you the status of the computerized handling system if handling isn't normal. "SLIP" will blink when VDC is operating. "VDC OFF" means the system is off. Turn the VDC system back on if the Nissan's handling is poor by pressing the "VDC Off" button until the light goes out.
2. Adjust your driving if "SLIP" comes on. "SLIP" means the road conditions may be slippery. The VDC aids in steering and stopping, but be careful, even if VDC is engaged.
3. Remove any aftermarket suspension parts like enhanced shock absorbers if the "VDC Off" light comes on and handling is bad. The VDC system is geared for stock equipment and tires only. Use winter tires or snow chains on snow-covered roads. VDC won't substitute for the correct winter equipment.
4. Don't drive on very inclined corners with high banks and leave the VDC switch on if the handling is poor with VDC on. The system can't operate properly in that environment. Disengage VDC, or avoid those kinds of roads.
VDC/ SLIP LIGHT ON
If a warning light is on, there's a trouble code stored in the computer. There are well over 800-1,000 possible trouble codes in the average late model vehicle, so asking us to guess what's causing your problem without knowing the code is a complete waste of time. Get the code read. Post it here. THEN we can help
1helpful
3answers
If i feel a grinding of my brakes after having my lower control arm and hub bearing replaced why am I steal feeling a grinding when I mash the brakes and it was from a rod connecter broke on the truck and...
I have a 2005 Nissan Pathfinder, the VDC light and the "Slip" light came on the dash, and the slip light was coming on while i was driving at the speed of 20 mph
2answers
3helpful
My brake, slip and VDC indicators stay on.
Check brake fluid level, add fluid from sealed container if needed.
Also check for leaking rear axle seals. Look for oil on the inside of rear wheels.
5helpful
2000 nissan maxima hard to start.
sounds like solenoid on starter is worn, replace starter.
3helpful
2005 Pathfinder - all warning lights on
was toll before disconnect the battery for five seconds and it will clear all the lights codes
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
