Question about Kodak EasyShare DX6490 Digital Camera
Can a faulty joystick be repaired/replaced?
Joystick controller does not work, can a part be purchased? Fortunately it is only an issue when the battery is taken out and charged. The date cannot be set nor the options changed but the camera works great (DX6490) and the newer cameras dont have the same options for the same price.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, The cost of the repair you are referring to will exceed the cost of a nice DX6490 on E-BAY. They all suffer from this problem with age,Bad design by Kodak.
Best Regards,Russell
Posted on Jan 23, 2013
SOURCE: joystick
While trying to fix this problem today I discovered something that seems to help, at least in my case. If I push down on the small button located below the joystick/onoff button, while also tapping the OK button, the camera responds to the OK. (This is the display/info button.) I'm not sure why this works or whether it would help in every case, but it would be worth a try. I've been able to finally set my date and make other changes necessary after recharging my battery.
Posted on Mar 11, 2008
SOURCE: menu wheel and joystick
took back of camera off 6 screws, and found wheel had skipped ofer plastic range limeters. took small screwdriver and popped them over limeters wile twisting. wheel works now but joystick does not work. also wheel spins but functions do not work.
Posted on May 06, 2008
SOURCE: my joystick only work up down and right
I had the same problem. I took my Z760 apart and put in a joystick from a used Z760. But the problem is that the joystick comes unglued from the small computer board. Take it apart and put a tiny drop of superglue on the joystick. Use a magnifier to line up the two little tabs in the proper holes. It should work fine.
Posted on Aug 03, 2008
gemmy23
  • 346 Answers
SOURCE: joystick blinks orange light
It sounds like it could be a couple of different things but it will be hard to tell without having the camera right in my hands. First you might want to check to see if you have a SD card in the cmaera. The internal memory may be full of your images and there is no room for anymore. If you have a sd card already in the camera then make sure it is not over 2gb. That model will only accomodate a 2gb card and nothing more.
Hope this helps
Posted on Jun 26, 2009
shockwave727
  • 262 Answers
SOURCE: Camera works fine other than the joystick. I
It means that the joysctick of camera is defective., Please call Precision camera and binocular repair to send the camera for service Its for US support 1 800 665 6515 or you may call kodak 1 800 235 6325 for an alternative options and solutions., Gudluck!
Posted on Nov 03, 2009
No lights on joystick
Here is a parts catalog for the M41. http://www.invacare.com/doc_files/06_108.pdf
If it was working fine before you swapped the batteries then you did something to interrupt the current flow. Pages 49/50 show the location of the controller with a picture. Unplug the connections here and make sure they are clean and in good shape. Make sure all other connections are clean and tight.
If you have 24V coming off the batteries into the controller, and 24V going out to the joystick from the controller and still nothing is working, then you will probably need to get ahold of an Invacare service tech to replace the joystick. Before he does that he should swap out the old joystick with a new one to see if that is the issue. Invacare parts are pretty pricey...joystick by itself is over $500.00. If the controller is shot, then you can double that cost. Sometimes, both need to be replaced as they can kill each other.
If the chair is old or has a lot of hard hours on it, you can usually shop around on Craigs List, etc and find a good newer/near new chair for about the same price as a new joystick replacement.
Feb 23, 2015 | Electric Mobility Invacare Pronto M41...
Lock key keeps blinkinglights blink 9 times
Depending on the controller type being used you either have a controller solenoid brake fault (sticker on bottom of joystick will say "PG Drives" and have 9-bars flashing) or a communication error between the controller and joystick (Dynamic Controller flashing wrench).
Repair for PG Drive is to replace joystick/controller.
Repair for Dynamic is to clean, remove and reseat or replace joystick cable.
Nov 12, 2013 | Pride Jazzy Select 6 Indoor Power...
I JUST PURCHASED A JAZZY WHEEL CHAIR AND IT IS I THINK 2003 MODEL WHEN TURNED ON THERE ARE 3 RED LIGHTS AND 4 YELLOW LIGHTS FLASHING AND NOTHING HAPPENS
the 7 lights indicate a joystick problem which means the joystick/controller will have to be replaced since there is no self repair fix Unless you can locate a good used joystick/controller for cheap (around $600.00 rebuilt) I would return the chair and get my money back Hope this helps
Jun 20, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Pilot Joystick is fried Type # D49637/8A. Can I get replacement? What is the cost? Guy
The Pride Jazzy 1115 originally came with the Pilot controller (Pride part # CTLDC 1030) and it has served you well. The manufacturer,Penny and Giles, is no longer manufacturing the Pilot. Fortunately, Pride is providing a new VSI controller 4 key 50 (70) Amp for the Jazzy 1115 (Pridepart number CTLDC1270 ) (manufacturer P & G part #D50148) for a retail cost of $1607. The new VSI controller will also need a new joystick mounting bracket assembly part #FRMASMB 4767 retail $30.
It is possible to have your Pilot controller rebuilt. There are many rebuild facilities that will sell you a reconditioned joystick (VSI or Pilot) for about $500 that will work on your unit. You can opt to send in yours for repair or reconditioning or purchase a reconditioned unit. Try MonsterScooterParts.com, TheAftermarketGroup.com, Wheelchair Wizard in Citrus Heights, CA.
The Pilot controller was a very robust unit but very expensive for Penny and Giles to manufacture. The new replacement VSI controller actually performs better and is more streamlined and smaller. The VSI pushbutton overlay (4 key) is very easy to use, The pushbuttons control on/off/speed increase/decrease. The replacement is easy to do as long as you remember to order the new mounting bracket assembly with the VSI because the old Pilot bracket will not work. All it takes to install is 2 screws to mount the control on the bracket, 2 plugs to connect, and 2 cable ties to secure the wiring. You may want to spray electrical contact cleaner into the plug receptacles on the electronics tray to clean them before plugging in the new parts. Hope this helps.
Nov 14, 2010 | Electric Jazzy 1115 Power Wheelchair
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
I recently purchased logitec extreme 3d pro joystick and a user manual did not come with it. How do I get one?
Did you purchase it open-box or second-hand? If so, you shouldn't be surprised at the lack of a manual. If you bought it new, it may not have come with one.
I personally have one of these joysticks, but I bought it so long ago that I can't remember if it came with a manual or not.
Either way, there really isn't much need for a manual for this joystick. It doesn't have any very advanced features that would require a manual. It's very simple to use:
  1. Plug it in to an open USB port on your computer.
  2. It should be automatically detected by your operating system. If not, you may have a defective joystick or a defective USB port. Try the joystick in another USB port. If the problem persists, check Logitech's website.
  3. In Windows, click Start->Control Panel->Game Controllers. You should see the joystick listed. Select it and click Properties.
  4. It should open a new window to the "Test" tab, where you can make sure all the buttons work. I suggest you click on the "Settings" tab at the top left.
  5. Click "Calibrate..." and follow the prompts. It'll ask you to keep the joystick centered and press a button on the joystick (use one of the side buttons such as 11 or 12 so that you don't inadvertently move the joystick from center).
  6. Then it'll ask you to move the joystick in complete circles. Do this several times and advance to the next step.
  7. It'll ask you to move the throttle slider up and down. Do this several times and advance to the next step.
  8. It'll ask you to set the "Z-rotation," which is the left/right twist of the handle. Do this several times.
  9. It'll ask you to center it and press a button. See step 5 above.
Now the joystick should be calibrated and ready for use. If you have multiple game controllers, you may want to click the "Advanced" tab back in the Game Controllers window and make sure the Logitech Extreme 3D Pro is selected as the preferred device.
Now start whatever game you want to use it with. You'll probably have to configure what you want the buttons on your joystick to do within the game; follow the instructions that came with the game.
Pretty simple, and like I said, there are no advanced macro functions or anything like that for this joystick.
Apr 10, 2009 | Logitech Extreme 3D Pro Joystick
Broken GC controller
yes you can. but only though the internet.
Mar 07, 2008 | Video Game Consoles & Games
Controllers freak out
Sounds like its time to buy a new controller, You could spend hours trouble shooting this one and for the price of a replacement its really not worth the time playing around with it and trying to repair it.
Sep 17, 2007 | Sony PlayStation 2 (PS2) Console
Kodak EasyShare DX6490 Digital Camera Logo
133 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
