Question about E-Machines AAFQ50400000K0 Keyboard
Cut, copy and paste keys
Hi
how do I get the cut, copy and paste keys to work on my keyboard modelKB-0108 when using microsoft words ?
Thanks
Bob
Ctrl+x -> cut
ctrl+v -> Paste
ctrl+c -> copy
Posted on Jul 01, 2009
Cut and paste
Learning how to cut and paste can make your life on the computer much easier.
It saves time and is more accurate that retyping the information, particularly if you do it several times.
If you know how to highlight words on your computer, you can easily copy sections of text and paste them somewhere else.
Open a text document or an email that contains some type.
Click at the end of the block of text you located in Step 1 and drag with your mouse back to the beginning of the text to highlight the entire block of type you wish to copy.
Release the mouse. The selected area should be highlighted in a color, usually blue.
Right-click the mouse on the highlighted text and a drop-down menu appears.
Select "Cut" to copy the highlighted text and remove it from its original position.
Select "Copy" to copy the highlighted text and leave it in its original position.
Paste the text you copied.
Right-click in an editable text box and select "Paste" from the drop-down menu.
The text appears in its new location.
Alternatively, highlight the text and hold down the "Ctrl" key on your keyboard while you press the "X" key to cut the text or the "C" key to copy the text.
These keyboard shortcuts copy the text that is highlighted.
To paste it, click in a text box and use the "Ctrl" and "V" shortcut to paste.
Cut and Paste Techniques in Microsoft Word
http://www.homeandlearn.co.uk/mw/s3p2.html
Aug 25, 2013 | Computers & Internet
Letter between c and b wont work! its the paste code key also and I dont recall using it to paste anything Whmat's your problem?
Of course, it wont work because you used a wrong short cut key. The correct short cut command for copying is press the control C simultaneously then for pasting it, it should control V simultaneously. Try it again using the right short cut command. Good luck!
Sep 20, 2011 | Microsoft Comfort Curve 2000 Keyboard
I want to "copy" and "paste" using the keyboard.
To copy -- Ctrl plus the C key
To paste -- Ctrl plus the V key
To cut -- Ctrl plus the X key
Jul 26, 2011 | Logitech Keyboard & Mouse
How do i get cut copy & paste on windows 7
There are standard keyboard options are available for cut, copy and paste operations. These are bydefault enabled in all type of windows based softwares.
Cut - > Ctrl + X
Copy - > Ctrl + C
Paste - > Ctrl + V
Above type of operations are allowed in all type of Windows Versions (95 / 98 / NT / 2000 / 2003 / XP / Vista / 7)
Thanks,
Amar
Oct 07, 2010 | Microsoft Computers & Internet
How can I copy the standby screen to Word Document, then probably edit it to paint?
I am not sure what exactly you mean when you say "Standby screen", if you mean the screen saver, then go to >display settings, > Screen Saver > then click Preview and while the preview is running, press "Print Screen" key on the keyboard, the image will be copied onto the clipboard, now close the display settings and paste it into the word document/paint.
We call this as "Screen Shot", you can also do the same with the desktop, suppose when you want to capture the image of your desktop, just press "print screen" key on the keyboard and paste it into the paint or other photo editing software and save it. Anything that you can see on the desktop/display of your monitor while the computer is running can be captured in the same way.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Microsoft Windows Vista Ultimate Edition
Cut or copy and paste does not work
That is very common problem and there is no one-best-sollution for it since they are tons of possible reasons.
Possible sollutions:
#1 close all programs
#2 switch off->switch ON pc
#3 scan for possible malware using antivirus software
#4 try using keyboard shortcuts crtl+c = copy or ctrl-x = cut
Leave rate if I helped you, thanks!!
Cheers,
Mike
May 09, 2010 | Microsoft Windows Vista Ultimate Edition
I am unable to cut and paste for the internet to microsoft works word processor.
try copy from internet and then use edit>paste special.....use unformatted text or text only....see the result...
May 12, 2009 | Dell Inspiron 531s Desktop Computer
Problem with keyboard sound control
i) print screen is option that will your current computer screen(in whatever position), when u press print screen an image of screen or current is copied in to your clipboard(cut, copy ,paste) now you have to paste  or copy it in some docu( it is like copying an image......), so now try to open an microsoft applications such as word, powerpint and paste the image in that by pressing ctrl+v or right lick and paste it... youwill an image of you screen.......
and you have to do this which made to think its not working
ii) coming to the volume button:
    sometimes youhave to load software or keyboard drivers that come with the keyboard, try this if not there must be mechnichal failure...
Thanking you
M. Sridhar
Dec 09, 2008 | Compaq Keyboard
Microsoft multimedia wireless print screen button does not work
I had this problem today with a new Microsoft keyboard. The Alt + Print Screen did not produce an image when pasted in Word.
We found that "F LOCK" button needed to be cancelled and this useful facility now works!!
Bob Wallace
Feb 25, 2008 | Microsoft Multimedia Optical...
Computers & Internet Logo
351 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
