Question about Sceptre X7GNAGAV 17" LCD Monitor
My display on the lcd monitor goes blank after startup.
I GET A DISPLAY FOR ABOUT 30 SECONDS AND IT BLANKS OUT.
    Scholar:
  • 44 Answers
It sounds like a backlight problem. It could be a problem with the inverter board or backlight itself. When the display "blanks out," can you still see a faint image on the screen -- especially if you look at an angle with some light shining on the screen? It is usually easiest to see changes on the screen - so after Windows boots, press the windows key on the keyboard repeatedly and look at the part of the screen where the start menu would appear. If you can see anyting, then it is definitely a backlight problem.
If it is a backlight problem, you'll need to disassemble the LCD panel to correct it. Correcting it might be as simple as re-seating or re-routing a loose or pinched backlight cable to as complex as replacing the LCD panel and inverter board. There is really no way to tell over the Internet. You'll probably void any applicable warranty by disassembling the panel.
By the way -- watch out, the inverter board can generate lots of voltage and reasonible amounts of current. I've never been shocked by one, but I've been careful.
Posted on Jul 01, 2009
I have samsung N120 Laptop.display has gone blanks but I can hear windows startup voice
Hook a spare monitor to the video output usually on the back, if picture okay! the inverter board is defective, " just below the LCD screen" or the backlight has failed, "just behind the display" but if both show the same symptoms it is the video graphics card normally built into the motherboard.
Apr 07, 2012 | Samsung Computers & Internet
Lcd screen goes on but then goes blank but rest of camera working
If your pictures after shoot are coming out well when downloaded , then it is the LCD display - the monitor to your view - that is faulty as the camera section is intact.
So if this comes on and then blanks out there is a possible chance that the Display is faulty, the driver to the display , possible electrolytic capacitors in the circuit or a wiring link to the LCD.
Remove and check only if confident and experienced but do not tamper a working camera.
Jan 22, 2011 | Fuji Finepix J50 Digital Camera
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
Lcd blanks out
Yes, that is one possibility. It could be the cable from the motherboard to the display. Inverters are fairly common problem.
May 14, 2010 | Toshiba Satellite 1805-S204 Notebook
VL 1716 monitor. The display blanks out after 20-30 seconds. When I turn the power OFF anf Back ON, the display comes back normal, then blanks out agin after 20-30 seconds. The power light stays green.
This is due to system goes to stand by mode or Hibernate mode. To disable, go to power management and disable or incrase the time for the same.
Revert back for more assistance. Also give your valuable feedback/rating on the same.
Feb 08, 2010 | Computers & Internet
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Acer Travelmate 6291 LCD monitor problem
Your concern is a typical problem with LCD displays/monitors. There could possibly be three (3) reasons why it is behaving as you have posted.
1. Backlight/Inverter problem;
2. LCD panel problem;
3. Video card problem.
You can do initial diagnosis by:
a. connect the laptop to an external monitor. Using the Fn + F? keys, activate the external monitor to be the default display. If it works, you have eliminated the possibility of the video card having a problem. If it likewise did not display anything or blanks out after sometime, then you have just confirmed that it is the video card that is a problem.
If you have ruled out the video card (using above procedure), you can proceed determining if it is an LCD panel problem or backlight/inverter problem.
To determine if it is a backlight/inverter problem, run the laptop normally even without a display. Let it boot and run through its startup sequence even if you can not see anything. Using a flashlight, shine a light obliquely to the face of the LCD display. if you can see some semblance of your desktop albeit dark, then you have just confirmed that it is the backlight/inverter. If even with the aid of a flashlight, the display s completely blank, then it is possible that the LCD display panel is defective. In some cases it is the flexible flat cable that is at fault.
With any of the aforementioned possible problems, opening the unit is required. This would need familiarity with electronic components and circuitry, use of a DVM and perhaps even a soldering iron. Should you not be comfortable doing this, it would probably be to your best advantage to seek the services of a qualifiedly professional.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Computers & Internet
Sceptre X7GNAGAV 17" LCD Monitor Logo
281 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
