Question about Remington 16" Electric Chain Saw
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is properly aligned along the chain guide. I don't see how the adjustment screw is supposed to do anything, because it is not clear what the little tab on the back end of it is supposed to engage with.
  • 188 Answers
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Posted on Jul 01, 2009
The chain on the 16 in chain saw keep slipping. Seems the thumb screw will not stay tight? Who can check this and fix?
First thing I would do would be to loosen the thumb screw fully so the chain is as loose as you can get it Next, loosen the chain bar and pull it out as far as possible which will take up the slack in the chain itself. Re tighten the chain bar. Afterward, you can perform detailed adjustment on the chain by playing with the thumb screw.
This solution has always worked for me and my various chainsaws.
Apr 12, 2011 | Remington 16" Electric Chain Saw
I have an Remington 3.25 (Peak Hp) 16"/40, 6 cm electric chain saw, And I have just a few questions 1.) Does it take oil/gas or just oil and if so what kind. 2.) How would I tighten the chain, its...
It uses oil only to lubricate the chain. The type of oil in not critical although special chain saw oil is available. If you use anything but chain saw blade oil, make sure that it is a light oil, both in viscosity and in colour because it is a total loss system and dark or dirty oil can become very messy. The chain adjustment is on the body at the end of the blade, it actually moves the blade in or out to set the chain tension. The chain should be tensioned that when it is pulled at the bottom, the guides of the chain should not quite come out of the slot in the blade. If the chain is too tight it overheats the blade and stretches the chain.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
Chain jammed on plant won't run after pulling most of plant from inner part of chain. Makes humming noise
The humming is the motor trying to turn. Remove the drive end cover from the bar and chain--back off the chain adjustment CCW several turns. If the saw has a chain brake, release it. When the cover is loose, remove the bar and chain, inspect the entire mechanism for any damage--particularly the chain itself. Run the motor without the bar and chain, and check for oil oozing out of the side port in the motor case where the bar fits. To reassemble, fit the bar in place after cleaning the small oil passages in the drive end, then fit chain over the sprocket. Pull the bar outwards to tighten the chain, then fit the cover and fasteners finger tight. Adjust the lower run of chain up to the bar (the lower run of teeth cut toward you), but not so tight that you can turn the chain by hand. Tighten the fasteners and recheck chain tension. Chain saws don't seem to like cutting hedges and other small branch, but tough bushes and the like. Make sure the chain teeth are properly sharpened. Hope this helps!
Jun 24, 2010 | Remington 16" Electric Chain Saw
Where can I order parts for my 16 inch electric Remington saw.
Usually any where that repairs lawn mowers, snowblowers, and chain saws or places that sell them like Sears.
May 13, 2010 | Remington 16" Electric Chain Saw
Motor turns --sprocket or chain doesn't
I'm assuming your kill switch is not engaged, the front handle should be pulled to the rear. It's normal to have some damage on the sprocket from loose chains catching on the corner so I doubt you need a new one. The motor turns? I'm assuming you're talking about the clutch, and if the clutch spins but the chain does not it sounds like your bar may be damaged or as you said the sprocket may need to be replaced if it's seriously been misused.
Apr 15, 2010 | Remington 16" Electric Chain Saw
Chain replacement.
Input "M12510US" in the model number here (if not your saw the procedure should be similar):
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
See pages 7 through 9, for use as a guide.
HTH
Lou
Are you aware RemingtonPower is no longer in production? Replacement parts are becoming difficult to find.
Jan 23, 2010 | Remington Electric Chain Saw
REMINGTON POLE CHAIN SAW
The chain has to be tensioned when replaced. You lift the chain away from the bar about halfway and the tangs that run in the bar should just almost come out of the groove. There is a screw that extends the bar near where it attaches near the sprocket. adjust that with the bar mounting nuts not quite tight till the chain is tensioned correctely.
Sep 28, 2009 | Remington Electric Pole Saw
The chain popped off and I can't get it to fit back on.
Losen the bar mounting nut, then losen the chain tension adjustment screw until the chain can be reinstalled, then tighten the tension screw until the chain just sags 1/8" or so at the center of the bar then retighten the bar mounting nut.
Sep 10, 2009 | Remington 16" Electric Chain Saw
The chain on my Remington electric saw keeps jumping the sprocket. Solution? Thanks.
Depending to what model you have, the Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. Or your cahin is not tensioned properly. According to the manufacturer... "The adjusting block on the adjusting screw isn’t inserted into the adjusting hole on the guide bar. Reinstall and align the sprocket cover by first removing the sprocket cover from the saw. Turn tensioning screw on the sprocket cover counter-clockwise until it stops. Pull guide bar away from saw body to remove slack from chain. Insert sprocket cover tab into saw body tab slot and lower sprocket cover into guide bar bolt. Finger tighten guide bar nut onto guide bar bolt. Slowly push guide bar toward saw body until adjusting block on the adjusting screw drops into round adjusting hole on the guide bar. Securely tighten guide bar nut after properly tensioning saw chain." If these tips do not work, you may need a new chain. You can order an new chain on-line at www.masterparts.net. I hope this helps you!
Jul 01, 2009 | Remington Electric Chain Saw
How do I get chain back on saw? And why does it keep coming off?
The chain must be adjusted so that pulling up on the chain you cannot see more than three guides. If the saw is really old you should invest in a new bar, chain and it its a gas model a new clutch.
May 26, 2009 | Remington Electric Chain Saw
Remington 16" Electric Chain Saw Logo
814 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
