Question about Nikon Coolpix S210 Digital Camera
Getting lens error
When you turn the camera on the zoom lens goes in and out and then you get a red "Lens error" ! on the screen.. Help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 24, 2010
When I'm taking a picture, and i try to zoom, it zooms a little then stops, says lens error and goes black. If i turn it back on, it goes on, I just can't zoom.
Most digital cameras jams are the cost of lens problems while zooming, with Nikon Coolpix S4000, simply use your fingers carefully pulling on the lens while turning the camera on. this can be done by getting your fingernail under the lens opening and gently pull.muunlyte5608.jpg
May 10, 2011 | Nikon Coolpix S4000 Digital Camera
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
Lens Error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Cameras
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
LENS ERROR
My Nikon L14 Camera Is Showing Up Lens Error
Can Someone Please Help Me.
Aug 22, 2008 | Nikon Coolpix L14 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
Nikon Coolpix S210 Digital Camera Logo
78 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
