Question about Whirlpool 24 in. Portable Dishwasher Dishwasher
Stuck on clean light always flashing
Hi i always have to reset my dishwasher to get it to work the code comes up 88 1d what does this mean DISHWASER Whirlpool gold
  • a_tucceri Jul 09, 2009
    I dont have a portable that was amistake I have a whirlpool gold quiet partner 3 and the repare man who came did check that already the arm and blade but thanks!!!!!!!!!!!!!
  • 11,896 Answers
There is something jammed in either the arm or blade that is setting off the code.
Posted on Jul 02, 2009
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
My whirlpool adp 4552 keeps on flashing 7 times...whats the problem?
This is not a solution, but a start. There should be a tech sheet somewhere with the dishwaser. Often it is stuck to the back of the kick plate. In this, or possibly in your owners manual, there should be a list of "error codes" This should explain what the seven flashes mean.
Good luck
Nov 17, 2010 | Whirlpool Dishwashers
Dishwaser problems
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 18, 2010 | Miele 24 in. Incognito G863 SCVi Built-In...
My dishwasher is stuck on clean mode? what can i do to reset? it finished cleaning, then will not cancel. just green flashing light that says clean. i tried to unplug the washer for about 1hr ,but no help.
The flashing clean light is an indication of an error during the cycle. I put together an explanation of this and how to reset the control so you can use the dishwasher again. Follow this link and let me know if it works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 04, 2010 | Kenmore Dishwashers
I have a quite partner 2 and it is stuck on the clean cycle and the light is blinking on and off. It will not work when I push any other buttons.
whirlpool dishwashers sense the water temperature in them the clean light flashing 7 times means either the heater element is not working or the water temperature going into the unit is to cold, start the water at the sink before starting the dishwasher now to get rid of the flashing light press the hi temp wash button and then the sani rinse button press one then the other over and over until all the lights come on it will then go in to a test mode when it completes the flashing light will go out that will solve your problem
Apr 03, 2010 | Whirlpool Dishwashers
Changed Electronic control on Kenmore dishwaser
Sounds like wsh motor is not running. Test cycle by pushing in order: hi temp, air dry, hi-temp, air-dry. All lites come on and unit will run. Should hear motor running when 'washing' light is on. If not then motor is bad or something stuck in impeller area. Please leave feedback.
Nov 25, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Hobart dishwaser
hi,i just read your issue.im a hobart service tech and fix these units all the time.what model do you have and are you sure the error is bof?let me know,i can tell you all the info,error codes about hobart dishwashers.
Jan 14, 2008 | Dishwashers
Odd fault codes then stops working.
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the filter or pump.
Sure enough there was.
1. Unplug your dishwaser at the wall. Check its off or disconnected.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
fyi
The third time about 1 year later this occured again and even hotpoint gave up as they could not fix the machine. (after multiple visits). I think that the two flashing lights are were a red herring and the dishwasher had a separate intermittent fault. Hotpoint replaced the unit for a mimum charge. Callout + 40.
Dec 31, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpiont fdw65 dishwasher fault lights
On the base of the dishwasher you have a anti fload switch, this has probably got stuck on or has been jammed when replacing the base of the dishwaser, I would take a look at this first.
Oct 21, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Jul 02, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool 24 in. Portable Dishwasher Dishwasher Logo
280 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
