Question about Refrigerators
Refrigerator not cold enough(65*)
Fridge side suddenly only cools to 65*. Freezer side makes ice but ice cream is soft. It's a Kenmore side by side (15yrs old) Are there any simple inexpensive fixes as due to it's age I'm reluctant to sink much money into it. It seems to be staying constant at these temps. Thanks in advance
  • 2 more comments
  • hickbone Jul 02, 2009
    I have defrosted the coils and recently restarted the unit. Should it come back up to the proper temperatures shall I assume it is indeed one of these defrosting problems(thermostat, heater or timer)? Thanks
    OK I've replaced the def.heating units(one definitely looked burnt out) and the thermostat. Tried to replace the control unit but the fridge wouldn't start up. Put the old control unit back in and it is cooling down now, as we speak. I will check to make sure the control unit replacement is identical. The replacement numbers have changed in a minor way in 15 yrs.
  • hickbone Jul 06, 2009
    I replaced the two def. heaters and thermostat and the fridge and freezer are both working better that ever. Cost under $75 for all the parts and saved having to shell out $1500 or so for a new one, at least for awhile. Thanks Woodchuck
  • 4,070 Answers
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 01, 2009
  • Charles T Nevin
    Charles T Nevin Jul 02, 2009
    If the ice build up was the problem it will cool back down to where it should and stay that way for several days or even over a week till the frost builds back up.
Why is my freezer not cold enough?
Check the freezer door seal is not leaky. Look for signs of moisture condensation along the door. Apply a thin film of Vaseline along door frame. This will make door seal stick better.
Also check there is no ice building up in freezer. This is a self defrosting fridge and built up of ice inside means warmer temperature. Lower the use of ice cubes from the ice maker to reduce load on compressor as this can effect freezer temperature.
Check freezer is not full of too many items causing reduction of air flow and hence reducing cooling effectiveness.
May 01, 2014 | Kenmore Refrigerators
Model TFH30PRTA NOT KEEPING ICE CREAM FROZEN
Ice cream will get hard when the temperature is closer to - 20 C or -1 F scale. Water becomes Ice at 0 C or 32 F scale.
Ice cream soft means your freezer is not cooling enough.
You were cleaning the coils? Both condenser and evaporator coils? Cleaning coils and then loosing cooling in the fridge is not a good sign or combination. May be there is a freon leak and the seal system is low on freon now.
Call a service tech to check the seal system.
Unfortunately, if it is a leak you may eventually buy a new fridge after spending money on freon fill up, freon system sealant, leak check etc etc... No good news. Sorry
Oct 25, 2017 | GE Profile Performance 29.8 cu. ft....
Fridge and freezer doesnt seem cold enough. Things are cool but not cold. Ice cream is not as hard as usual (soft but not melted). Ice maker not making ice. Adjusting thermostat doesn't seem to make a...
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Aug 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Kenmore side bt side isn't cooling. The
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 98d4754.jpgIf this was a slow moving loss you should clean the cooling coil under the refrigerator. Remove the bottom snap in grille and vacuum out the dirt and dust from the coil and anything else you can reach. You may need to make an extension with paper towel tubes flattened a little and tape to get into the cramped spaces. I use a piece of clear plastic pipe stuck in the suction with a long angled split cut on the cleaning end. Maybe also move the fridge out, vacuum and clean the flooring area also. (And every 6 months)
Apr 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer too cold--refrigerator too warm
If the cold control is not adjusting the temp when you move it, that can be part of the problem.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
My side by side is not cooling well on either the freezer side on the refrigerator side...have both sides jacked up to nine ...it is still cooling but not cold enough!! The ice cream is soft, but the meats...
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath
Aug 07, 2009 | Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
265 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
