Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Where is the drain for a 2003 harley fat boy
Where is the drain plug for a 2003 harley fat boy
  • 48 Answers
On the bottom of the oil pan on right (brake) side jus behind the tranny
Posted on Sep 28, 2009
  • 42 Answers
There should be a hose that come off one rear corner of the oil tank, it either goes straight down to the frame with a plug directly underneath (has oil o'ring #11105). It could also just be a line that is attached to the swing arm with a hose plug in it and a funny spring clamp holding the plug in the hose. I think 2003 is the first solution though.
Posted on Aug 10, 2009
  • dancass Aug 10, 2009
My 2002 Harley Fatboy drain plug is not a 5/8 bolt socket, but a allen wrench/ THex type fitting. Any help on what to use to remove plug
Did you use the appropriate hex head to fit in the plug to get it out , you can go to Harley and get a replacement plug
Jun 06, 2014 | 2003 Harley Davidson FLSTF Fat boy
Where is the oil drain plug for a 2000 harley fat boy
Hi Anonymous, drain plug is in the bottom of the frame, right side, all the way to the rear. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 02, 2014 | 2000 Harley Davidson FLSTF Fat boy
Where is the transmission fill tube for an '02 fat boy?
Top right side just below yer engine oil reservoir but above the frame rail about 10". An allen head plug, approx. 5/16ths faces up & forward @ about a 45 degree angle (it's your dip stick too) Takes about 1 qt. ??? Q is...how do you DRAIN it ???
Apr 13, 2013 | 2003 Harley Davidson FLSTF Fat boy
2005 fat boy oil change
Stand the bike upright. Remove the dipstick from the oil tank. Remove the drain plug on the bottom right side of the frame. While the oil is draining, replace the oring on the drain plug. Remove and replace the oil filter, after filling the new filter half full of oil. Replace the drain plug. Put 3 quarts of oil in the oil tank. Replace the dipstick. Start the bike and check for leaks. No leaks, you're done! I use HD Syn 3 synthetic oil in my '04 Fatboy, but you can also use a conventional 20w50, as long as it's made for use in and air cooled motorcycle. Don't use car oil!
Nov 04, 2012 | 2003 Harley Davidson FLSTF Fat boy
Harley Davidson 2003 FLSTF Fat boy spark plug number
Hi Anonymous, the HD 6R12 spark plug is gapped at .040" Have nice day.
May 09, 2012 | 2003 Harley Davidson FLSTF Fat boy
What is the plug with 5\16 allen on the front of oil pan on 2003 88inch twin cam harley engine?
That is the engine oil drain plug
The transmission drain is the one on the bottom right
Aug 03, 2011 | 2003 Harley Davidson FXDL Dyna Low Rider
Can't find oil plug for 2003 fat boy
Look down at the bottom of the frame behind the exhaust pipes. There is a large hose that runs down that way with a plug in it. Harley moved the drain plug to a crossmember underneath the frame. The plug screws upwards into the crossmember.
Good Luck
Steve
Sep 12, 2010 | 2003 Harley Davidson FLSTF Fat boy
Will exhaust from 2003 harley fat boy fit a 1999 harley fat boy
I doubt it. The Fat Boy is a member of the Softail family. In 1999, the Softails were running Evolution engines. They didnt' go to the TC-88B engine until 2000 and that required a frame change. I don't think it will fit but you never really know until you try it.
Steve
Sep 07, 2010 | 2003 Harley Davidson FLSTFI Fat Boy
WHERE IS THE OIL DRAIN PLUG
Follow the tube going straight down from the oil tank under the frame (right side) and you'll find the drain plug.
May 06, 2010 | 2003 Harley Davidson FLSTF Fat boy
How do I change the oil on a 2002 fat boy? Where is the drain plugs?
On the fatboy, the oil drain plug should be on the right side, just under the frame, directly below the oil tank. The primary drain is on the left side under the derby cover on the bottom. The tranny drain is on the bottom towards the rear pretty much centered.
And, as our darlin' little miss piglet said, a maual is worth the investment.
Jun 28, 2009 | 2003 Harley Davidson FLSTF Fat boy
Lands Phones Logo
111 people viewed this question
Top Harley Davidson Lands Phones Experts
Gar
Gar
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
