My computer is locked can't remember my password
Use Ophcrack its free
I would like to introduce Windows Password Reset Tool . it not only supports XP, 2000, and NT, I have personally tested it with Vista and windows 7. It works perfectly to reset any local user account to a blank password. I Wrote it to an 1GB USB flash drive do this. Booting up and clearing a password takes a minute or two works like a charm. You can download it . It also supports cd/dvd. http://www.windows7password.net/
SOURCE: password forgotten
Depending on other things that you have set up, you may be able to log in as the "Administrator"
Try the following.
If you have not assigned a password to the system administrator account, this will get you in.
You should see a login that asks fro your username and password.
Then you can go to users in the control panel and re-set the password on your other account.
SOURCE: locked computer ..can't remember password
if you failed to logon throgh administrator... then some software is restricting to logg on. it can be a virus.. try to repair your operating system. thre are some softwares that can break software by using boot option.. search software on internet if not format the operating system
Firstly, use password prompt function on password locked computer
If you have set the prompt option when you set account password, it
may help you remember something about your forgotten computer password!
Secondly, reset computer password with default administrator account
Once we install Windows OS, there will be automatically generated an
"Administrator" account with blank password. Therefore, if we forgot
password on computer, we can have a try:
a. Boot system, and press Ctrl + Alt + Del keys twice when the Windows login screen comes up.
b. At the Classic Login window, input: Administrator and keep Password box null. Then press Enter key to login.
c. Recover computer password by: Control Panel - User Accounts.
Thirdly, find computer password with computer password reset disk
If we created this computer password reset disk before we forgot
password, we can opt for the disk to help us unlock password
efficiently.
a. Click OK and close the message box on the password incorrect prompt window.
b. Click "Reset Windows Password" and insert the password reset disk.
c. Do as the "Password Reset Wizard" to create a new password.
Fourthly, change computer password with Windows Installation Disc
Take computer Windows XP as example:
a. Start computer using Windows XP Setup CD.
b. When it asks to repair our current Windows installation, choose
"Accept" it and press "R" to run the repair. Then computer will begin
to repair our Windows and copy files to hard drive.
c. Setup will reboot system. Please don't press any key when there is "Press any key to continue..."
d. Now computer will do other tasks and there will be a progress bar
displayed. Please notice carefully the details shown at the bottom of
screen.
e. Once "Installing Devices" comes up, press keys: Shift+F10. Input:
nusrmgr.cpl and press Enter key at the Command Prompt window.
f. The same "User Accounts" window will display as it is in Control
Panel. Choose "Administrator account" and select any account listed to
change or remove your computer password.
Fifth, break computer password by DIY a password recovery disk
If the above four methods still can't help us reset lost computer
password, we can refer to this way now. DIY a password reset disk after
forgotten computer password means that we burn an .iso image file from
Windows password recovery software into a bootable CD/DVD/USB disk.
Now, take one of the top-rated Ainorsoft Windows Password Recovery
Corporation as example:
a. Download and install Ainorsoft Windows Password Recovery Corporation in any accessible computer (not from computer you want to unlock)
b. Burn an ISO image file to CD/DVD/USB Flash Drive
c. Set locked computer to boot from CD/DVD/USB Flash Drive and set the BIOS Setting for CD/DVD/USB Flash Drive.
d. Reset forgotten computer password to default Re123456.
The above ways on forgotten computer password reset are the collections of best bet for us to unlock lost computer password! So even if we forgot computer password, things will be OK soon!
source: http://www.windowspasswordrecovery.net/article/forgot-computer-password.html
Asus Eee PCs run on the Windows XP SP2 operating system. Accounts in Windows XP SP2 can easily be password-protected, but the same password can just as easily be forgotten.
At moments like this, you'll wish you had chosen a password that is both secure and easy to remember, or kept a record of it in a private place.
The quickest way to get back on the computer is to seek out someone with an administrator account on the computer.
Press "Control" + "Alt" + "Delete" at the same time on the locked screen.
Select "Switch User."
Remember, only an administrator account registered on this computer can unlock the computer.
Type in "administrator" in the user name box.
Type the password that corresponds to the administrator user name in the password box .
Click "OK." The Asus Eee PC is unlocked.
Hope this helps
