Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Although i have a new toner it keeps saying Install black cartridge
    Novelist:
  • 102 Answers
Make sure Maler Strip is removed from the cartridge.
If yes than swicth off the printer removed the cartridge and restart the printer without the cartridge once printer completes the initialisation process without the cartridge than put the cartridge in and check if the message disappears and upgrade the firmware of the printer to the latest one using the link given below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
Posted on Jul 02, 2009
Installed toner cartridge samsung clx6200fx and it keeps saying install toner what is wrong
Did you get a Samsung toner cartridge or an off brand? Toner cartridges have small chips that tell the printer how much toner is left.. Not all of those chips will work correctly.
Mar 28, 2016 | Samsung CLX-6200FX Printer
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
Samsung scx4725fn cannot seem to recognise new toner.Keeps on saying INSTALL TONER
Install Toner .When this copier is not recognized toner cartridge.If is not this model cartridge or some of missing.please check it properly.You can get an idea install your old cartridge.If the same massage,please check your printer any parts were broken.
Dec 27, 2009 | Samsung SCX-4725FN All-In-One Laser...
MFC-7840w keeps saying "toner life end"
After I figured this out, it was quite easy to resolve. Remove the toner cartridge from the drum cartridge. Remove the black plastic cover on the left side of the toner cartridge (3 Phillips screws). There is a "flag", which is a small plastic tab on the outer side set to the right at about 2 o'clock. Turn the gears until you fully reset the tab going counterclockwise to the 10 o'clock position (fully to the left). Reinstall the small black cover and the three phillips screws. And the idea to install black electrical tape over the small clear plastic windows on both sides is also a good idea to prevent the early and false message that the cartridge is empty. Make sure you do not allow that tape to get into the gears.
Sep 25, 2009 | Brother MFC 7840W Printer
I am trying to reinstall the black ink cartridge to a hp2605dn and it keeps saying the error 10.1000
I found this info on the web for you, guessing you are using a recycled or generic cartridge:
The HP LaserJet 2300 toner cartridge has a smart chip on the top left side. This chip tells the printer when the toner is low.
Recycled toners do not or can not reset the chip, therefore when you use a recycled toner you may get toner low messages although the toner is good.
Also, you may get the 10.10.00 error. There is a work around to fool the printer into not displaying the message.
Place a strip of opaque tape or paper on the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
No guarantees but it seems plausible.
Jun 19, 2009 | HP Color LaserJet 2600n Printer
Won't recognize toner cartridge
go to: www.fixyourownprinter.com
the solution is to reprogram the eproms on the cartridges, easily done.
Dec 17, 2008 | Samsung CLP-510 Laser Printer
Epson Aculaser C1100N - Black Toner problem
IF the problem persists with an original cartridge then the factory settings should be restored refer the manual or go through the settings in the control panel . minimise the tone of printing . If toner is getting accumulated in the printer then it might be due to refilled toner not the original cartridge . use the original cartridges
Nov 18, 2007 | Epson Aculaser C1100 Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
472 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
