Question about Mitsubishi VS-50605 50" Rear Projection Television
No picture . tvturns, immediately turns off
As soon as I turn the tv on. it immediately turns off.why? mitsubishi vs-50605
  • 2,071 Answers
Your TV set is in protect mode .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted.
Good luck;
Regards:
VOTIT
Posted on Jul 01, 2009
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Timer light flashes 3 times
the code means that your tv power supply is not functioning your tv needs to be repaired call the tech.good luck
Apr 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
358 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
