Bosch maxx wfl 2450 - Fabric conditioner not being taken
The Fabric conditioner is not being taken out of the tray, I have cleaned the water inlet as thoroughly as possible.
  • 236 Answers
SOURCE: Won't take Fabric Softener
get a stiff washing up brush and scrub the fill holes above the powder tray. the conditioner fill hole may be blocked or is squirting out sideways. if not there may be a faulty fab cond water valve.
Posted on Jun 01, 2007
  • 1314 Answers
SOURCE: Bosch Maxx WFL 2260
thanks sorry i have no hands on experence with bosch as im in usa and dont have many in my neck of the woods but there are bosch experts in here
Posted on Jan 17, 2008
  • 139 Answers
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
  • 4 Answers
SOURCE: Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Posted on Sep 05, 2008
SOURCE: bosch 1200 maxx wfl 2400
one soution might be to check the drain hose, it might be clothed.
Posted on Dec 13, 2008
  • 3463 Answers
SOURCE: changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Posted on Jan 05, 2009
0 characters
1 Points
Bosch maxx 1000 - when finished cycle, leaves central fabric conditioner drawer full of water + trace of condtioner.
Check that the hose that connects the drawer to the tub is clean, fabric conditioner normally gunks up especially on colder wash cycles.
Apr 01, 2015 | Bosch Washing Machines
How to remove *** wire from bosch wfl 2450?
Here you go....
Aug 21, 2014 | Bosch Washing Machines
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric...
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric conditioner section is remaining full of water
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Maxx WFL 2450 Washing machine Electric fault
hi there sounds as the watyer leak has found its way into the motor windings and damaged the motor..and the control module.....could be a very expensive repair
regards Sir Galahad
Aug 18, 2009 | Washing Machines
Bosch Maxx WFL 2000: Conditioner Water not filling.
take out the tray. In the roof of the powder tray there is a thin strip of plastic that runs over the conditioner tray, it has 4 square holes in it, if you look closely it is secured by clips. prize them apart to flip down the piece with the 4 holes in it. you will find that it is all blocked up with black gunk, clean it out with whatever is suitable ( i used an hair grip). put things back and check it by putting the washer on a rinse, after a min it will flush out more gunk and things should work fine
May 20, 2008 | Washing Machines
Bosch wlf2260
clean the detergent tray especially the part for the conditioner. on some bosch the rinse water valve is seperate uie different valve for water for main wsash. check valve is not open circuit resistance should be about 3.8k. could also be due to low water pressure
Mar 11, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Flashing Active Light and not taking fabric conditioner
1: The flashing wash light usually indicates a problem with the door latch while a flashing rinse/spin light usually indicates a problem with your inlet valve. 2: The cold water inlet has 2 independant outlets. The issue that you are describing indicates that one part of the cold water inlet is not opening to allow water to flow to the proper dispenser port.
Mar 10, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
296 people viewed this question
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
