Question about Singer 8280 Mechanical Sewing Machine
Singer 8280 bobbin thread not taken up by needle
I tried differnet times but the thread from the bobbin is not taken up by the needle. When i put the bobbin thread manually through the hole to the needle and start sewing, the machine does not sew (because bobbin thread is taken up...
has anybody a solution for this or what should i look for?
thanks a lot for help !
  • 111 Answers
Needle in backwards?
Posted on Jul 08, 2009
How do you get the needle to hook up the thread from the bobbin? I have tried 10 times and with a new needle...nothing....help!! Many thanks for ur help
With sewing machines you always need the guide to threading. If you give your make and model I will try and find you the manual.
Post as a COMMENT
The thread from the upper bobbin goes around the tensioner and through the arm at the rear, and then through the hole in the needle. The lower bobbin has to be threaded through the case and then through the hole on the shuttle. The lower bobbin has to be locked in place.
Jun 12, 2016 | Sewing Machines
I can not pick up the thread[string] from under the machine,both the strings on the needle and under the machine should be on top of the table to start sewing
If this is your first time sewing on a machine then:
Once you make sure the needle is threaded and the bobbin is sitting correctly in the bobbin casing, and you have installed and manipulated the thread according to your manufacturers instructions:.
Holding the end of the thread that you threaded through the needle, use the wheel (right hand side of the machine) and rotate it toward you pulling the thread that you are holding gently toward you.
The bobbin thread should give you some restriction and the end of the bobbin thread should have come through the hole in the needle plate (the metal plate that sits under the presser foot on the table of your machine.
Hope this has helped.
Jan 21, 2015 | Sewing Machines
Thread bernina embroidery bobbin
The thread sensor eye is probably dirty.
Dec 26, 2017 | Bernina Sewing Machines
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
My machine is not picking up the stitches. I have rethreaded, checked needle and tension.
try these suggestions
Not picking up thread can be several issues
1.bobbin is miss wound
2. bobbin case isn't snapped in properly
3. you're using the wrong type bobbin
4. needle is bent or burred
5. check bobbin area for lint & loose threads
6. little oil--check operation manual for this
7.machine is out of time --done by service tech
8.check automatic thread cutter to see if it’s bent
but most of the time the issue is once again mis-threading or the thread coming off take up lever
sewing machine needles put in incorrectly
Check & make sure needle is in the needle holder correctly.
Check your manual for threading diagram
check bobbin area including case for lint & loose threads
Take the needle plate off & clean under neath it ( if your machine has screws that hold the needle plate on be careful NOT TO DAMAGE THE SCREWS) because a damaged screw that has a burr on it can pull fabric
Each time you start to sew
1.make sure there’s 2 to 3 inches of top thread when you put the needle down for the bobbin thread
2.make sure there is a 2 to 3 inch of bobbin thread so the top thread can pick it up
3.Pull the tail of the top and bobbin thread behind the presser foot
hope these help--please rate this with the thumbs in the upper right hand corner-thank you
Aug 06, 2010 | Sewing Machines
Consew 226 r sewing machine
do you have the user manual?
Sep 15, 2008 | Consew 206RB
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Kenmore 385. 11607 needle jams into shuttle or shuttle race
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Dec 17, 2007 | Kenmore Drop-In Bobbin 505S-21BH...
Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Nov 12, 2007 | Kenmore 12102
Singer 8280 Mechanical Sewing Machine Logo
617 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
