SOURCE: no sound from back surround speakers
I resolved the problem by going in the dec mode (page 49 of manuel) and changing the setting to Pro Logic. That did the trick. Good Luck all.
SOURCE: We have a SONY DVD Home Theatre system
Each device has its own normal level for the signal. Usually they are set at the standardised value - 500mV - but sometimes some devices don't follow the standard. The only thing you can do is to check the connectors and use another cable - bad cables or connector can cause a big drop in signal level. If even after using a new, good quality cable that is a tight fit in the plugs - and these plugs themselves don't move around - then the only thing you can do is to set the maximum volume level higher to partially compensate for that. You can find this option in the HDMI setup section in the MENU, labeled VOLUME LIMIT..
SOURCE: Need replacement speaker cables for dav-hdx576wf
Since noone else gave you a good answer I will. I lost some cables to mine a while ago and found this awesome jerry rig solution; Go to radio shack, and ask for '14-16 gauge star ring terminal connectors' Should come in a pack of 10 and be about 2$. On the back of the unit where these connectors fit, there should be two prongs. You will need two star-rings for each connector slot. Wire up your connectors and crimp the ends LIGHTLY with a pair of pliers. The star-ring connector connected to the negative wire should be inserted to the left prong, (left if you are facing the back of the unit), and the right prong is the positive. If you did everything correctly, you should be able to make your own wires for sony stereo systems whenever you need to. Saved my ***, hope it did the same for you. Here is a link to what they look like. http://www.shopping.com/radio-shack-non-insulated-crimp-on-star-ring-terminals-10-pack/info
