Question about iLO Televison & Video
Television only has one working line across the screen
My nephew's television only has one line across the screen that works, the rest of the tv is blank. I was told that for a while before that it would do this and then later the whole screen would work the next time it was turned on. It did this back and forth for a while until now it is just the one line working.
  • 4,234 Answers
Assuming that this is a CRT type TV, the problem is either bad solder connection at the vertical IC or a defective IC. If you could post the exact make and model of the set, I can provide a more detailed description of what needs to be done.
Thanks,
Dan
Posted on Jul 01, 2009
32 INCH ZENITH PICTURE IN PICTURE ABOUT 15 YEARS OLD.PICTURE DISAPPEARED AND ONLY HAVE A THIN WHITE LINE RUNNING ACROSS THE SCREEN.THE SOUND STILL WORKS FINE. IS IT WORTHWHILE GETTING IT REPAIRED ??
When CRT TV's show only a white/bright line horizonatlly It is a failure of the flyback Transformer. Not all that costly to repair. Your old TV will probably still be working when all the latest plasmas and rear projections have been laid to rest. Fancy junk TV's dont get any better programs than those old reliable ones
Please rate my help++++Thanks for using FRIXYA
Aug 04, 2010 | Televison & Video
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Our Toshiba HD tv has gone on the fritz. Every so often when we turn it on their is a single line across the middle of the screen, the rest is black. you can hear the program that the TV is tuned to. Any...
The vertical output ic needs re-soldered, look for a 5 pin ic connected to a heat sink near the flyback, re-solder the pins. If you are not up to this a local shop should be able to do this and it should not be an expensive tv repair.
Sep 02, 2009 | Toshiba Televison & Video
Line across middle of screen, rest of screen black
The problelm is a defective vertical deflection system. Could be the amplifier, vertical output driver or whole printed board that supports the vertical deflection activity. It is considered to be a serious failure.
The cost of repair will be around $200 to $300.
Aug 05, 2009 | Hitachi 50UX58B 50" Rear Projection...
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Red red wavy lines across the TV screen
I did not fix the problem, but you have the model number wrong, it is KP-46WT510
I do need some help.
Nov 23, 2008 | Sony KP-43HT20 43" Rear Projection...
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
SAMSUNG TV
Possible bad color wheel..need lamp code # to get correct
wheel part #.........................................T.
Nov 15, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Televison & Video Logo
37 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
