Question about Dishwashers
Hi i have a whirpool gold dishwasher i always have to reset the panel to use it cause its stuck on clean light always on the code that come up when i reset is 88 1d what is the problem?
  • 20 more comments
  • a_tucceri Jul 01, 2009
    No i have electricity and when i reset it it works the motor runs but when its finished it stays on clean then i have to reset to do another load AND A CODE COMES UP first 88 then 1d what is that its supposed to tell you what the problem is thats why i pais for this adivse I dont need you to tell me to check if its ppluged or to check the motor I need more specific please!!!!!!!!!!!!!!!
    and how do i do these tests the code should tell you what the problem is thats what i understood!!!!!!!!!!
    i can reset it by pushing on the normal and the sani rinse 5 or six times then it resets the panel and codes come up 88 d1 then 12 and it counts down from 16 mins its running to do a test do u know whats going on i gues the count down is to test what element isnt working properly!!!!!!!!
    my diswhasher whirlpool gold is stuck on clean light always flashing i reset it by pushing on normal and sani rinse 5 or 6 times a code comes up which is supposed to tell u what the prob is this code is 88 d1 then 12 and then the machine does a self test for about 16 mins to test all elements I can do a load afterwards but the minute its finished it gets stuck on clean light again and i have to do this process over to reset it what is the problem can anyone tell me!!!!!!!!!!!!
    hi kevin i had a repair man come and check eberything im sure its plugged but i will check again there was debris in the chopper its been removed I still have those damn codes come up and still gets stuck on clean!!!!!!!
    still waiting for 88 d1 12 code on my whirpool dishwasher can anyone tell me what this is i always have to reset it by pushing on normal and heated ry to get this code come up then it does a self test for 16 mins the machine works afterwards for one load but then the clean light is on and i cant get it to work unless i reset again the MACHINE IS PLUGED AND SO IS THE MOTOR!!!!!!!!!!! it works it the test and for one load after i reset it can anyone help!!!!!!!!!!!
    how do i do that ???? where would that be ???????
    k its under my sink lol found it should it be opened or closed or half way??????
    k maybe...i found the valve under my sink is it supposed to be opend closed or half way??????
    water valve under sink are fine just checkd
    anyone help w dishwasher whirlpool gold clean light blinking reset it code 88 d1 12 comes up then it does a self test for 16 mins and im able to do one load afterwards cause its reset but then blinking light comes on and cant get it to work have to reset again and again
    everthing is plugd there is no bulbs in a dishwasher and it still stuck on clean i thought there were dishwasher experts on here its a dishwasher thats flashing clean wont stop and wont allow me to use it
    where do i get that...........im not a repair man how can i test it.....like i said the machine tests itself does a test cycle and then gives the defective code 88 d1 12 i need to know what that is to be able to fix the problem its a whirlpool gold quiet partner iii
    the dishwaher whirlpool gold quiet partneriii does a self test when i reset it by pressing the normal and heated dry 6x the code comes up 88 d1 12 then it resets allowing me to do a cycle but then the clean light stayes flashing so i have to reset it again i have to know what the 88 d1 12 is THATS THE DEFECTIVE PROBLEM DOES ANYONE KNOW
    yes its a whirpool gold quiet partner iii model # 8535034
    and your the first to ask me thanks im gettung frustrated with this machine i just want to make it work it cost me 1600 4 years ago and i had a repair man come twice who cants seem to fix the prob!!!!!!!! 300 buks later
    is that what the codes represent??
    i cant seem to fins it!!!!!!!!!!!!!!!!
    can it be a sensor prob im outta luck her no one seems to know what that 88 d1 12 is and it wont dtop flashing
  • a_tucceri Jul 02, 2009
    can it be because its not leveld the water sensor my water senosor levler is in plASTIC what has to be soldered?
  • a_tucceri Jul 16, 2009
    i cant find the manuel and its still not working there is nothing in the arm or blade seem to run when i reset it but then it james on clean!!!!!!!!!
    how do we reprogram
  • 583 Answers
Ok collected the data for this model.its the problem of water level sensor.it needs to be replaced to solve this issue.it is to be done by a technician as it requires bit of soldering too.its not a type of do it yourself job.thanks.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jul 01, 2009
  • livetech Jul 02, 2009
    the sensor is plastic but when it senses the water level.it sends a commant to the board.the component that accepts this cammand is to be resoldered by a tech or may be replaced if faulty.should cost approx
    18 dollars for a part plus tech charges.
  • 749 Answers
Hi, can you give me the make/model of the diswasher whirpool (model) thanks
  • Muzzammil Ishfaq
    Muzzammil Ishfaq Jul 01, 2009
    seems like the error code is indicating that there is a internal main board fault, there is a chance that you will have to replace the main control board which will be expensive.
  • Muzzammil Ishfaq
    yes, the code IS indicating of a internal fault with the main control board, it could possibly need reprogramming. do you have a manual?
  • 294 Answers
Was looking for ur ans for last 30 mins.. m runnin outa time.. n best plase to find the code is this link..i guess..as such there is no code as wat u mentioned.. please contact a local expert so as he/she can have first hand idea of the trouble..
Have a look here for help!
http://www.ukwhitegoods.co.uk/module...ays=0&start=50
  • 11,896 Answers
This is a system fault, mostly due to faulty capacitor on the main board causing the problem. The machine will have to be tested to find the corrupt capacitor that will need to be replaced. A multi--tester can be used to find faulty capacitor.
  • 66 Answers
You might need to check the bulb to see if it is in the socket of the panel correctly , this most likely is the problem if not that you should try to see if all of the plugs are in the correct place, to get the dishwasher out simply chip the glue from where it is on the counter and it will slide right out allowing you to check the plugs. Another thing you could try if worst comes to worst you can call the dealer that you got it from to see if they can help you with the problem. Good luck hope i was helpful
  • 3,230 Answers
this error code related to water valve, check that first.
Thanks
    Genius:
  • 1,847 Answers
This link will help you.
http://www.applianceblog.com/mainforums/showthread.php?t=15830#post74658
Thanks
Kindly rate the answer
Kevin
    President:
  • 942 Answers
Hi, you just do this
  • Test the timer motor
  • Test the thermostat
  • Test the heating element
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Good luck
Regards
PCmania
  • Neciforo Llanto Jul 01, 2009
    Hi, to just try to reset your unit by unpluging for 5 hour's the porpuse for this is to drain the stored current in the memory
    Regards
    PCmania
Whirpool quiet partner 3 gold. panel lights work and say it is wasing but doesn't start
The timing circuit may be defective and the circuit board needs replacing. Have an authorized serviceman do a continuity test on the board and have it rest to factory specs.
Feb 27, 2014 | Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
I have a Whirpool D/W Mod. GU2275XTVYO. The clean light flashes 7 timed, pauses and flashes 7 times again... Is that in the board? It will cancel and drain but won't do anything after that. Please...
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 25, 2011 | Whirlpool Gold GU2275XTV Builtin...
Dishwasher won't reset, stays on gree-flashing light- Clean cycle
HI,
This is an indication that the water did not heat properly. I have put together some instructions on what can cause this and how to reset the control so you can use the dishwasher again. Follow the link below and let me know if this helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Stuck on clean light always flashing
There is something jammed in either the arm or blade that is setting off the code.
Jul 01, 2009 | Whirlpool 24 in. Portable Dishwasher...
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
Dishwashers Logo
290 people viewed this question
Top Dishwashers Experts
