Question about Fuji PrintPix NC-1000 Thermal Printer
There is a red line about 1/4 on photos
There is a red line about 1/4" on the right side of the photos. We have used three other cameras with their own cards and all of the pictures have the red line. What could be the problem?
    Champion:
  • 220 Answers
Drum or belt has a problem
Posted on Jul 02, 2009
How to fix three red flashing on instax mini 7s? I had change the battery and it work but only for a short time
  1. Amazon.com: Questions and Answers: Fujifilm Instax MINI 7s White ...
    www.amazon.com/Fujifilm-MINI-7s.../-/-/1?_... Amazon.com, Inc.Questions and Answers on Fujifilm Instax MINI 7s White Instant Film Camera. ... Sort: Most Helpful first ' Newest first. Showing 1-10 of 31 questions. 3. votes ... Now when i take photos the photo turn out black What can i do to fix Jun 1, 2015.
Jul 21, 2015 | FUJIFILM instax mini 7 Digital Camera
Mutiple lines on right side of photo
try removing the ink cartrage and clean the heads in the printer with a quetip and rubbing alcohol. same with the cartrages.
Nov 12, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
I cannot get an E-size plot to print properly. I have no trouble with plotting D-size drawings. What are the correct settings to use to print E-size sheets?
Printing high quality photos using an inkjet printer is not only possible, but affordable too. Top notch quality relies on a few factors: the right paper, the right ink and the right settings. Read on to find out how to print photos with an inkjet printer.
1.Use a good digital camera. For 4x6 and 8x10 prints, you will want a camera with at least two or three megapixels.
2.Buy photo paper. Spend the extra few dollars to get high-gloss photo paper that is designed for your printer.
3.Use photo ink. High quality photos take high quality ink. Do not use the same ink that you use for documents.
4.Optimize your settings. Select "File > Print" then click "Properties" and find the preferences or quality tab. Set the quality to the highest or choose a photo preset.
5.Edit photos on your computer. Import your photos from a CD or your digital camera. See your camera's manual to find out how.
6.Crop and resize. Cut out anything extra in the background that you do not want and resize the picture so it will fit on the page.
Sep 19, 2011 | Canon iPF700 InkJet Printer
Red light nat bottom right side of camera
Its circuit fault and it might be for water logged or battery leakage water or at the time of transfer photo through USB
Mar 10, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Red lines in photos and pics too red?
Your CCD image sensor is failing. Believe it or not, Canon will fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Nov 06, 2009 | Canon PowerShot A80 Digital Camera
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Epson 1280 red lines on photo
Suggestion:   Open up the "hood". All the way on the right side of the top of the plastic case, you'll see a large switch.   Switch it up from "0" to "1".  This will give the paper a little more room and might help.
Jul 27, 2008 | Epson Stylus Photo 1280 InkJet Printer
Three colors line up on some spots but not others
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Zenith IQB50M90W 50" Rear Projection...
Camera picture problem
I think it is time fot you contact the Tech Support site. If it is more than a year old it may be time to replace it download this to see if is of any help http://www.fixya.com/support/p423-nikon_coolpix_5600_digital_camera/manual-10378
May 21, 2007 | Nikon Coolpix 5600 Digital Camera
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
Fuji PrintPix NC-1000 Thermal Printer Logo
104 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
