Question about Ricoh FAX2900L Plain Paper Laser
Ricoh FAX2900L printing too dark
I just replaced the toner cartridge and now it's printing too dark to even read. I can't find any key or function to lighten the print. How can I lighten the printing?
  • 313 Answers
Re: Ricoh FAX2900L printing too dark
Check the scanner white roller witch is under the front cover where you feed in the paper to be scanned sometimes this gets dirty you can take it out by releasing the levers on each side..this also sets the density for copying.. if you have just put a newe cartridge in also check that it is seated properly as the contacts for the charge might not be connecting properly
Posted on Jun 11, 2009
0 characters
3 Points
Why is it printing solid black pages?
The replacement toner cartridge may have been installed incorrectly.
Mar 31, 2016 | Ricoh Aficio SP 100e Laser Multifunction...
Insert toner card
I think you mean insert the toner cart, meaning just that, if you just put a new one in is it OEM, and if it is try gently shaking it to unclump the toner in it. -Carl
Jul 07, 2009 | Ricoh FAX2900L Plain Paper Laser
Toner empty message after replacing the toner Ricoh fax2210L
menu # 1934 menu search for new cartridge and then click yes yes ,turn power off and on.
Jun 18, 2009 | Ricoh FAX2210L Plain Paper Laser
Ricoh fax 3310, when printing has dark background on left side, new drum has been installed.
Ricoh's Support suggests reseating the toner cartridge or re-distributing the toner inside the cartridge. This makes sense since you're experiencing darkness only on 1 side of the page. I hope this helps you with your issue and wish you the Best of Luck!
May 11, 2009 | Ricoh Fax Machines
Printed pages look terrible...
I'm more familiar with HP printers, but it sounds like a fuser is bad. The fuser effects print quality as well. If you've replaced the toner, as you have.
Apr 24, 2009 | Sharp FO 5550 Plain Paper Laser Fax
Fax2900L machine not working according to set user parameters
You have programmed the broadcast with 1 too many numbers using the 10 key method. You wioll have to remove just 1 of the numbers in the broadcast. Not one of the quick dial numbers or one of the speed dial numbers, but one of the numbers you entered using the 10 key pad. I believe the maximum is 10, but you must leave 1 free for the memory to work.
I see that you have programmed 53 numbers for this broadcast. Why not assign speed dial numbers for those that you have used the 10 key pad for?
May 09, 2008 | Ricoh FAX2900L Plain Paper Laser
Just want to know the real price
Hi Ms Belle, this is an older model fax and you can probably pick one up second hand for around $100-$200 dollars
May 07, 2008 | Ricoh FAX2900L Plain Paper Laser
Toner Cartridge reading has empty but have replaced toner
Try to see in the software if there is any reset option for the toner.
Nov 06, 2007 | Ricoh FAX2500L Plain Paper Laser
Ricoh FAX2900L Plain Paper Laser Logo
214 people viewed this question
Top Ricoh Fax Machines Experts
Are you a Ricoh Fax Machine Expert? Answer questions, earn points and help others
