Question about Whirlpool WFC7500VW Washer
Wont work when i put a wash in light just flashes
  • 2,071 Answers
Check this all this can cause that your washer is not working:
  • Check that the washer is plugged in securely
  • Check the circuit breaker or fuse box
  • Test the outlet for curent
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Test the water level switch
  • Test the timer control
  • Good luck :
    Regards:
    VOTIT
    Posted on Jul 01, 2009
    Wont start
    Try unplugging it and turning it on again. It is telling you something is not correct, it could be a simple thing as the door. Double check that the door is closed properly. Do it slowly, put some light pressure on the door and see if the lights go out. Good luck!
    Feb 15, 2016 | Washing Machines
    My washing machine wont turn on, it is plugged into an extension lead which also supplies the power for my dishwasher. the dishwasher works fine but the washing machine wont turn on at all, the lights...
    It is nothing to do with the extension lead you are using, sounds more like a board problem to me, or another fault causing the lights to flash.
    Jan 03, 2011 | Washing Machines
    Wont stop flashing time on express cycle
    unplug it for 40 minutes to reset the CCU.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Dec 08, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    My washing machine stops and the red "door locked" light keeps flashing. Can anybody tell me how to put this right?
    door interlock has failed and it wont lock. so the washer safety device will not let it work, replace door interlock by an approved engineer
    Oct 25, 2009 | Whirlpool Washing Machines
    Door light flashing when machine put on
    Suggestion: Put the machine off, try some WD40 on the machine where the lock is (not on the door). Then open & close the door a few times. After a couple of minutes try the machine
    Mar 01, 2009 | Hotpoint Washing Machines
    Hot point wf541. have top 2 lights on wont pump
    Hi.
    The sequence of flashing lights is in fact indicating an error condition on your m/c.
    It indicates that the m/c has failed to drain, possibly because the pump filter is blocked.
    Your m/c is fitted with a filter system for the pump,
    The filter may have become blocked, see care and maintenance in your handbook, in your handbook for details on how to check and clean the filter.
    Also make sure the door is shut properly.
    If after you have checked all these points, and it still does not work properly, then I suggest you have someone to look at the m/c, or replace the pump if it does not appear to be working.
    Hope this helps.
    Please leave feedback.
    thanks.
    Nov 30, 2008 | Washing Machines
    Indesit W123 washing machine
    it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
    Mar 31, 2008 | Indesit W 123 Front Load Washer
    Whirlpool washing machine
    Hi, I have the same problem with the same machine! I've tracked it down to a broken belt.
    Jan 15, 2008 | Hotpoint WMA40 Front Load Washer
    Washing machine stops mid cylcle
    try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
    May 10, 2007 | Whirlpool AWM6120 Front Load Washer
    Whirlpool WFC7500VW Washer Logo
    306 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
