yes most certainly, with leaks it is either the seals or cracks in hoses or rust holes in wash cylinder, but most likely the first too because of being a fairly new model
I used work on these all the time, if the glass and door gasket are not clean you will not get a proper seal and it will leak, most common fault is pet hairs between the seal and the glass causes a small break in the seal and it weaps slightly. give both the seal and the glass a clean.
My hoover 1600 washer is flashing stop, ready to start but the start button doesn't work when...
(More)
My hoover 1600 washer is flashing stop, ready to start but the start button doesn't work when pushed??????
hoover aaa 160 s e has stopped working. creaseguard, start & door locked buttons flashing...
(More)
hoover aaa 160 s e has stopped working. creaseguard, start & door locked buttons flashing together intermittently. Help!
How can I remove sludge build-up completely from the reverse side of the washing machine drum. this...
(More)
How can I remove sludge build-up completely from the reverse side of the washing machine drum. this I think is the cause of stains on white clothes
