Question about Toshiba TZ55V61 55" Rear Projection Television
Toshiba TZ55V61 having prob. w/red,yellow lights
Have had no problems up until yesterday. It looks like the projector is mixing up the colors as I get at the bottom of the tv red & green lights. Most of the actors on the tv have green or red lips or hands. I have not tried to fix anything myself yet.
  • Scheibs Feb 18, 2008
    Problem started when turning on today. Screen is now too wide and convergence is off. Trying to bring up convergence adjustment screen. Picture is off to the left. Can't see 1,4 or 7 to adjust. Can adjust other numbers, but doesn't help much.
  • 1,694 Answers
Convergence issue...replace STK392-110 IC's on small PCB
mounted by itself above power supply....................T.
Posted on Jan 10, 2008
Change color for bx 286
go into the menu and select factory reset. that should do it.
Mar 01, 2014 | LG Bx286 Projector
I work in a school and one of the projectors has a yellow area in the centre of the projection. The lamp has been replaced ?
Your Blue LCD Light valve is burned or has dust on it which blocks the blue color.
With RGB, the absense of blue (Red + Green) is yellow.
If you're lucky a simply cleaning at the light valves will solve your problem. Otherwise your looking $$ for a new LCD valve.
May 18, 2011 | Hitachi CP-RS55 LCD Projector
Hitachi projector problem
Many Hitachi projectors use 3LCD technology which supposedly makes colors more realistic. 3LCD means that the projected light must pass through 3 seperate LCD screens. Each screen has one color but when mixed, they form a nice picture. I would guess that one or more of the LCD screens have gone bad. That is a hardware problem that I would recommend talking to the manufacturer about.
Mar 03, 2010 | Hitachi Performa CP-RS55 Multimedia...
Problem with eyeclops video projector...after
unplug all rca cables from your eyeclops, then try all three colors one at a time, into the yellow colored hole on the side of your eyeclops, until you get a picture, and you have to have the dvd player on and playing a dvd, otherwise the light won't come on your projector, then plug in the audio sources, the yellow and white. When I got my eyeclops mini projector, it wouldn't work at all when I plugged the yellow rca cable in the yellow hole on the side of the eyeclops, the red into the red, and the white into white. Only when I placed the red rca cable into the yellow hole on the eyeclops, the yellow into the red hole, and the white rca cable into the white hole did it finally work. That was for my dvd player. With the video game function, I plugged each color Rca cable into their same colored holes on the eyeclops and it worked fine, but again, you have to have your device, whether it be a dvd player or game system on and running before your eyeclops led lights will turn on. Not sure I had to switch colors when I played my dvd player, but that's how it works on my mini projector, anyways.
Jan 17, 2010 | JAKKS Pacific Eyeclops Bionic Eye Tv...
Our project seems to have lost a color. The
may have fried fly-eye (diffuser) lens and fried light filter on one or more of the lcd panels. both due to excessive dust and heat. unfortunately, you'll have to replace the entire optical engine. toshiba doesn't sell individual parts.
Aug 19, 2009 | Toshiba TLP T70M Multimedia Projector
I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Nov 25, 2008 | Toshiba TDP-T45U DLP Projector
Toshiba tv-model tz55v61
If the red,green and blue mixture adjustment is what you want...
remove front lower speaker grill & access panel..locate RGB
adjust on Screen / focus block.......slightly adjust screen controls for best not adjust focus controls.....T.
Jan 10, 2008 | Toshiba TZ55V61 55" Rear Projection...
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Back screen lights are out of sync
This projection TV is made up of 3 projectors R G and B (Red,Green,Blue) These colors mix to create the other colors all you have to do is both convergences
Nov 10, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Open Questions:
Toshiba TZ55V61 55" Rear Projection Television Logo
178 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
