Question about Garden
My vigoro water timer i bought at home depot will not stay on manual off/om or on its program. I have installed the new 9 volt battery correctly since i can program ok but it shuts off in a short time thereafter.same with the manual ?? any ideas ??
I have a Vigoro 271-687 in which has worked well except when i change the batteries it wont reset and will not work do you have any solutions to this problem i really like this product just dont understand the prob
Posted on Aug 01, 2010
This may help with part of your problem, but if you want to water manually (overriding the program) and you press the manual button, the water will stay on for only half an hour, so to continue you need to simply hit the manual button again. The 'shutoff' after half an hour is automatic.
Posted on Jun 17, 2010
I have the same problem. Good to know on the 1/2hr shutoff. I guess it is going back to the store. I'd say this is not a good timer. I bought a nice one with more options for things like skipping days, multiple times per day. This one is not only low tech, but it doesn't work. Nice job!
Posted on Aug 05, 2010
  • wincht Nov 05, 2010
    I have 5 of them and they are all doing the same thing, great product until the batteries die then it is junk. And try and call to get anyone to take care of it. Good luck.
I am having the same problem with my vigoro water timer. I called the number given on the package and left a message.
Posted on Apr 09, 2010
I changed the battery on my Vigoro water meter but the numbers no longer appear on the screen; what can I do?
Clean battery terminals.
Reset timer, and see if functionality is restored.
Some timers go bad when battery is replaced. For example that is frequent complaint with Intermatic ST01C, etc.
Jun 14, 2012 | Hardware & Accessories
SunSmart 15312 - timer has power and will turn lights on/off manually but will not turn on/off automatically after setting program.
Sun Smart is new GE timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
There is no repair for defective timer, except buy another at Home Depot and return defect in new package.
When I bought 15312 timer for testing, I found many packages at Home Depot were taped together as if people returned the timer. The large aluminum fin shows that timer is expected to get warm.
When testing the timer, the door stuck, and the timer seemed cheaply made. Intermatic brand timers are more robust at this time.
The instruction manual is not clearly written as could be, and timer requires a lot of button pushes for each setting.
Because the instruction manual is complex, requiring multiple button pushes for each setting, I suggest writing out the steps to make sure nothing is skipped over.
If lights turn on-off with override, then timer should be wired correctly.
Be sure to reset timer before programming.
Press setup button twice to begin programming.
Check programming for conflicts and overlaps that will cause timer not to function as expected.
For example selecting days of week. If program1 ON says turn on at 7:00 pm all days of week, and program1 OFF says off at 9:00 pm Tuesday.
Another point of confusion is Dawn-Dusk-Time. If you want timer to turn ON at 7:00, then select Time.
Sep 21, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I need instructions to the Vigoro- Duo Deluxe water timer 9 volt battery operated # on back is 0708..# on fromt top left is 225-379 Purchased at Home Depot I has5 to 6 cycles that can be programmed. I...
The vigoro duo delux might be same as Melnor 3100
Open following links:
http://www.melnor.com/instructions.php
http://www.melnor.com/instructions/3100_InstructionSheet.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Hardware & Accessories
Tork model dts200a/dzs200a shows no display and has stopped working. any Suggesqtions?
Tork DTS200a/DZS200a is 2-channel digital timer with 365 day programming and astronomic capability.
2-channel means that timer can control two different circuits with different program schedule applied to each circuit.
http://waterheatertimer.org/pdf/1TORK.DTS200A.DZS200A.INSTALL_OP.pdf
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DTS
1) Timer has 'snap-in non-rechargeable 9-volt lithium battery'
Replace with ordinary 9 volt battery
Battery location is not apparent from image of product, and I don't own this particular timer line.
Add a comment and say where battery is located.
2) Programming is stored indefinitely in memory chip even if battery goes dead.
Current time might have to be reset shown in manual page 3.
Memory can be cleared using procedure outlined in manual starting page 13.
3) If timer function is not restored, then timer might have gone bad.
Contact NSI:
http://www.nsiindustries.com/contact-us.aspx
Many timers and other electronics are not protected from power surge.
Lightning strikes, electrical storms, and simple power outage can knock out electronic timers, and water heaters, water softener, treadmill, etc.
1-event Surge protectors can be installed in main panel to help protect circuits and electronics.
Aug 30, 2011 | TORK Hardware & Accessories
We have a Vigoro Two Zone Water Timer. The timer started beeping and flashing that the batteries are low. We put new batteries in and it is still beeping and flashing low battery. What do we do now?
The timer is no good.
1) Clean battery terminals and make sure battery polarity is correct.
2) If you bought timer at Home Depot, call:
Internet Customer Service Center at 1-800-435-4654
3) If you live near Home Depot, then buy new timer and return defect timer in new package.
4) Here's what Home Depot customers say about this timer: the product will fail after 4 months, only worked one season, failed right out of box, new batteries did not restore functionality, etc. Only two good reviews.
Take a moment and vote on fixya answer:
Aug 26, 2011 | Hardware & Accessories
I have the Vigoro (196-036)/Melnor water timer. I bought it last year to replace a different model. I replaced the battery and set the program this year, but the program isn't working. I can use it...
At the
Bottom right there is a button to turn the program on and off. Make sure you have it on. I think a black little
Bar shows if it is on.
May 07, 2011 | Garden
I have a new Nordik digital indoor timer TD133B. It has never displayed information on it's screen. The instruction manual indicates plugging it in for an hour to charge the battery. I did this but still...
Most plug-in timers have rechargeable battery that is not replaceable.
Instructions say: Plug in timer for hour and then unplug it to set programs.
Intermatic makes a couple plug-in outdoor timers with replaceable batteries that load from back of timer, but otherwise batteries are rechargeable.
If battery will not charge, then display doesn't show, and that signals the timer is no good.
Take timer back if you can, and exchange for another.
I was looking at timers in Walmart and Target yesterday (since my specialty, and interest is timers).
New plug-in timers are inexpensive.
Lowes and Home Depot also carry inexpensive plug-in timers.
Be sure to save timer instructions because generally, store-bought timer brands don't show manuals on-line. Except GE brand timers from Home Depot.
Add a comment if you need more help.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Nov 25, 2010 | Hardware & Accessories
Vigoro water timer problems
I also had this problem and found that the water pressure was too high. I turned the water spicket down one a a half turns (yours may vary) and now it's working fine.
May 05, 2009 | Garden
Garden Logo
2,914 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
