Question about ASUS Intel 440LX Chipset P2L-N Motherboard
I need a CD-ROM drive and cable for an Asus P2L-N/P2E-N board
I am trying to add a slim CD-ROM drive to my Asus motherboard. It can only be done by connecting it to their 50 pin connector on the board. I have tried a dozen as a slave on the primary IDE channel and they are either invisible or conflict the hard drive (the hard drive is set as a master).Do you know where I can buy the miniature 50 pin cable and most important where I can buy either the drive ready to install or he 50 pin to slim drive adapter board. I am speaking of the small board that attaches to the back of the drive and converts the 50 pin cable to the miniature connector that is on almost all slim laptop type drives.
I have run into this exact problem when trying to add a 50 pin cable CD-ROM drive to a thin client Unisis box and gave up on it too.
  • 61 Answers
Is this what you are looking for?
As for the conflict with the master drive, double check the jumper settings. Some drives have different settings for Master, Slave and Single drive. When given the option, try CS (Cable Select) and them them sort it out themselves.
It's also not usually recommended to connect an optical drive on the same cable as a hard drive. Sometimes you can't help it, but the optical is going to slow down the transfer rate of the HD.
Posted on Jul 01, 2009
I am unable to connect a cd rom from an old pc to my new emachines because there is no "ribbon" to connect the cd to? How else can I connect it to the motherboard? The CD doesn't have a SATA...
Look on the mother board for a ribbon connector.. double row of pins.. Some boards will have a legacy connector. If not.. you can buy an adaptor to connect IDE CD to board,
BUT.. for about the same cost, you can buy a cheap new CD-DVD RW - burner.. probably with far better peformance than an old one. About $25 should do it.
Dec 13, 2010 | E-Machines emachines (emachinees) CD-ROM...
My motherboard doesnt have that long prong connector for the cd rom drive so how do i connect the cd rom drive?
What you will going to do is find a nearest computer store in your place and buy the connector for your cd rom drive.
Oct 25, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
Addinga card reader to an ASUS M2V m/board
Install a PCI usb card to give you the USB connectors.
Feb 16, 2009 | ASUS M2V Motherboard
Power supply not coming on
first of all you need to connected the power supply connector, processor connector, hdd connector, cd rom connector.
check it
Jan 21, 2009 | ASUS A8N-SLI Premium Motherboard
No video
Go to the Asus website and download the drivers for this board. It's most likely that it did not come with drivers installed. Hopefully this will fix the problem. Good luck.
Dec 23, 2008 | ASUS P4V8X-MX Motherboard
What type of CD-ROM should I use for ASUS P5QL-E Board
As the others have said, your MB has an 40-pin IDE connector just to the right of the SATA connectors. It is at a 90 degree angle to the SATA connectors and parallel to the RAM slots.
It is shown on Page 2-26 of the manual. (Available at http://support.asus.com/ )
Remember there is a pin missing so that the cable cannot be inserted backwards.
Dec 10, 2008 | Computers & Internet
No Video
Try another power supply. I believe you would have this problem if your 4-pin connector from the power supply is not connected to the board. Of cause, you might have a defective board.
May 22, 2008 | ASUS A8N-E Motherboard
Ribbon hook-up
You should be using two, two connector IDE ribbon cables if I understand your questions correctly.
On IDE 0 you connect the hard drive and one cd drive.
On IDE 1 you connect the second cd drive.
You will need to make sure the jumper settings on the drives are correctly set.
Jan 02, 2008 | Computers & Internet
New Installation P5N32-E SLI
There is also a 4 pin power connector cable for the processor to connect onto the motherboard. Make sure that is plugged in. IF that still doesn't help, disconnect hard drive, video card, cd rom drive and floppy drive and any other pci cards in the system. Try booting it again at least to the bios. See if that helps.
Mar 27, 2007 | ASUS P5N32-SLI Deluxe (890552603794)...
ASUS Intel 440LX Chipset P2L-N Motherboard Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
