Question about Polaroid FDM-0715 Television
Remote control problem
Changed battery in remote still does not work / ive had this problem for some months now/ like the product just need to know what to do about remote/
0 characters
1 Points
Remote Controller not working, Where can i buy the remote controller for this Sony DVD Home theatre.
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site Check this site too. If you see these sites by "MOSAIC" or "Magazine" view will make surf easier.
Universal remote controls are available at most of the electronic spare part selling shops.
Jun 10, 2014 | Sony DAVTZ710 - 5.1ch DVD Home Theatre...
RM-GA014 remote can't switch Sony Bravia 46" tv on
Follow this procedure to troubleshoot if the TV does not respond to the supplied remote control.
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the remote control buttons are jammed.
  4. Install fresh batteries into the remote control. IMPORTANT: Make sure the batteries are inserted in the (+ and -) direction shown inside the battery compartment.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV. IMPORTANT: Some locations can interfere with the IR signal from the remote control. Glass enclosures, as well as fluorescent or halogen lights, may prevent the IR signal from reaching the TV.
  6. Point the remote control at the IR sensor of the TV.
  7. Press the POWER button and other buttons to test TV operation. IMPORTANT: Do not hold down the POWER button too long. Doing so may prevent the remote control from operating the TV.
    • If some of the remote control buttons operate the TV but others do not, the remote control may need replaced.
    • If all of the remote control buttons work, no further troubleshooting is required. Otherwise, continue troubleshooting below.
  8. Try using the remote control at varying distances from the TV. IMPORTANT: Using the remote control too close or too far away may prevent the IR signal from reaching the TV.
  9. Turn the Light Sensor setting to OFF.
    1. On the TV itself, press the HOME button on the TV.
    2. Using the up arrow or down arrow select Preferences.
    3. Press the INPUT button.
    4. Press the up arrow or down arrow to select ECO.
    5. Press the INPUT button.
    6. Use the up arrow or down arrow to select Light Sensor.
    7. Press the INPUT button.
    8. Press the up arrow or down arrow to select OFF.
    9. Press the INPUT button.
  10. Power reset the TV.
  11. Make sure the TV has the latest system software (firmware) update installed, if applicable.
The troubleshooting steps above should resolve the issue. If you completed all the steps and the issue is not resolved, service may be required or the remote control may need replaced. Contact the Customer Experience Center at (239) 768-7547 to speak with a service representative for further assistance.
Apr 07, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
I can not get my remote control to work, even with batteries replacement
The remote can be tested---most shops or even electronics stores have a remote tester--point remote at it and press a button and strip on tester either lights up or not.
Also----some digital cameras when remote pointed at lens will show if remote is working(push button (any) on remote with camera on.
Mar 23, 2012 | Coby Portable Televisions
WIRELESS REMOTE CONTROL - MODEL - r2t3/r2t4. Wonder if you can help please! Have an Electric Adjustable Bed with a remote which has stopped working. Details on the back of the remote are - Model No:R2-T3....
I have a remote for adjustable bed that won't work. I know it is the remote, because I put a new 9V battery in and the red light doesn't come on. Model No:R2-T3. FCC ID: MGB _R2-T (03-680252-03). I see someone posted the same problem and don't see any recommendation to fix or replace it.
Jan 05, 2011 | Portable Televisions
TV Remote Stopped Working
remote senser on TV chassis needs to be replaced
they go bad alot.
Feb 15, 2010 | Philips PR0930X 9 in. Portable Television
Remote not turning tv on
if your tv set can be switch on manually then you need to replace the remote control.have you tried changing the batteries of your remote?maybe it is already dead,if you tried then buy a new remote control.
Nov 30, 2009 | RCA Portable Televisions
I have a Coby TV Model TF-DVD1256 which is a 5.6
Consumer Care / Technical Support
  • Toll-free: 800-727-3592 (8:30AM to 9:00PM on weekdays, 9:00AM to 5:30PM on weekends)
Oct 22, 2009 | Portable Televisions
Tv not responding to remote control & cant get rid of pop up menu
The problem is not in the remote,is inside the TV,it might be memory system IC,it's better you bring this a TV repair shop maybe it cost you only $50.
Hope it may help you;
Jan 07, 2009 | Portable Televisions
Tv remote doesnt work on tv
Not all Philips TVs use the same remote codes.
It is very unlikely that the TV remote receiver is the problem (trust me).
Is this the original remote for that set?
If not, try program it as a universal with the other Philips codes or get a universal remote and do the same.
Here is the website for remote codes:
Jan 02, 2008 | PROimage PRO IMAGE 5" BLACK&WHITE TV...
Polaroid FDM-0715 Television Logo
Top Polaroid Portable Televisions Experts
Are you a Polaroid Portable Television Expert? Answer questions, earn points and help others
