Automatic? trans, mines a 6speed, and has a clutch.
my guess is yes,
my A/T will not change gears,
all gears slip? (slip , flare or?)
or wont move at all. the car?????
or is stuck in1st gear in drive.?
or wont move in reverse. why not tell full story on so complex a device. super complex it is.
wont up shift , wont down shift
skips gears.
check fuses first.
then scan the PCM, it will tell you errors, called DTCs
use a real scan tool that can scan 2010 Jeeps. (factory codes !!!)
not some autozoned junk.
id bet there is a code, for sure.
even a broken shifter switch, or?
