Keyboard malfunction. when spacing ; appears. key c does not wor. goes to address bar. v is pressed the number 4 also appears
  • Tim otoi May 11, 2010
    Is quite a common problem. I am asssuming you are on a pc and that nothing has been spilled on your Keyboard recently. Quite often what happens is that the computer for some reason gets confused with which language settings your are using (different parts of the world have different layouts etc..) This can be solved by
    Click Start, point to Settings, and then click Control Panel.(or just get to your 'control panel')
    Double-click Regional and Language Options.
    Click the Languages tab.
    In the Text Services and Input languages pane, click Details.
    In the Installed Services pane, click any keyboard listed other than US, and then click Remove.
    When the confirmation message appears, click Yes.
    Repeat step 5 until all listed keyboards except US or UK depending on where you llive are removed.You might need to restart your pc after this to effect the changes. (If this still doesn't solve your problem. Then you need to borrow another ketboard from a friend and test whether you get the same malfunction with their keyboard. If you don't get the same problem something is wrong with your keyboard and it probably needs replacing)
  • 101 Answers
Hi, keyboard malfunctiopns can be caused by a few things. One of the major causes is liquid (the stickier the worse) being spilt into the board but if you are sure thats what hasn't happened then there are are other options. Am assuming you are using a windows pc? Sometimes the computer can get confused with regional language settings(different countries have different keyboard layouts)
If this setting gets changed it can cause problems so try
  1. Get to the Control Panel in windows.
  2. Double-click Regional and Language Options.
  3. Click the Languages tab.
  4. In the Text Services and Input languages pane, click Details.
  5. In the Installed Services pane, click any keyboard listed other than US (US or UK depending on where you live), and then click Remove.
  6. When the confirmation message appears, click Yes.
  7. Repeat step 5 until all listed keyboards except US or UK are removed.(Hopefully this will have solved your prob. If not borrow a friends keyboard, try it out on your pc. If you dont get the same problems with the borrowed keyboard then something is wrong with yours and it probably needs replacing)
Posted on Jul 01, 2009
How do I inout my e-mail address? I do not see specific instructions on how to shift keys from alphabetic to numeric.
Should be a number/ special character button bottom left of keyboard by space bar. mine is 1@# press that button
Nov 19, 2016 | Computers & Internet
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
HOW DO I FIND MY SECURITY CODE ON MY NETGEAR N300 WIRELESS ROUTER?
Hi.
You can temporarily hardwire your computer to the router (connect via ethernet), press start then runand key in CMD, press enter on the keyboard and a black window will appear. Key in ipconfig and press enter. Information about your connection will appear, including the default gateway (write the numbers down or try to remember it).
Open internet explorer and go to the GUI (graphic user interface), key in the default gateway (the numbers) in the address bar, then press enter (the address bar is the long white bar at the top part of intrnet explorer that says "address" in front.)
This will give you access to your router. Find the option to see the "network key" or reset the it.
Note: resetting should be your last resort
Jun 04, 2011 | NetGear WNR2000 Wireless Router
I am unable to do a question mark symbol - how do i do this...also how do i do a backspace symbol..... thankyou!
To the RIGHT of the "space-bar" on your keyboard is the 'ALT(ternate) GR(aphic)' key. Hold-down that key, and press the '?' key, and a '?' should appear on your computer's screen.
Jul 03, 2010 | Gateway 2520915 Keyboard
When I hit the space bar it eitherdoes
is a stuked key bar, normaly bellow key is a metalic part, is out of place, and stuck key when pressed.
Jan 09, 2010 | Logitech Cordless Desktop MX3200 Laser...
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
http://www.laptopkey.com/installation_guides.php
Oct 10, 2009 | Dell 0Y3740 Keyboard
Space bar types a space and a '/' hash /mark
you should go to control panel then click on keyboard setting and reset your key board or put on screen keyboard
Apr 13, 2009 | Sony VAIO VGN-FS550 Notebook
NAVMAN S45 GPS SET UP
http://www8.garmin.com/manuals/nuvi750-GPS-Atl_OwnersManual.pdf
click the link
model is different but system is same.
Dec 17, 2008 | GPS
Space bar when pressed gives me a number 4
Try turning the keyboard upside down and shaking the crumbs out. If that doesn't do it, try blowing it out with canned air between the keys.
Dec 14, 2008 | Computers & Internet
Keyboard not working.
Press the FN+NumLock key - you have probably switch on NumLock???
If not, then the keyboard cable has probably come loose.
Look for some way to remove the keyboard. Sometimes a screw from underneath, sometimes two or three small catches at front of keyboard (small gaps in metal plate in front of space bar). Sometimes top plastic bar above keyboard slides sideways.
Keyboard cable uses goes into a header socket - to refit:
Switch off and remove battery and power first!
1. Prise up each end of the socket with a blunt knife - the outer part of the socket should move up a few mm
2. Push keyboard cable down fully
3. Push down each end of the header socket so it is flush with the lower part of the socket.
4. Test keyboard
Aug 16, 2008 | Compaq Presario Notebook
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
