Question about Weber Q Grill
Gas flow problem...
My Q-200 worked fine off my 20lb tank until I thought it was empty. When it emptied I purchased a 5lb tank to take camping.  Worked to begin with but then stopped.  I tried a small coleman tank and again it worked. I put the 5lb tank back on and it worked for a while and then stopped...very frustrating...now I realize also that my 20lb was not completely empty-is this a regulator problem?
    Problem Solver:
  • 5 Answers
Stick with the one pound disposable propane bottles & you will be fine. The 5lb tank is not compatable.
Posted on Aug 13, 2009
My 1998 Hyundai Elantra will not start after running out of gas.When I put gas in it ,it would crank but it took a long time to start. I drove it 3 miles and it shut off. I cranked it and cranked it,but it...
Don't let the car run out of gas. Fill the tank and run until the tank is half empty. Again fill the tank.
By driving until you run out of gas, you are letting sediments/dirt collected in the bottom of the tank to enter the engine. Rather they will block the fuel filter. Then gas will not reach the engine.
Clean the gas filter and your car will run fine.
The same advice again. Don't drive until the tank becomes empty.
Aug 30, 2011 | 1998 Hyundai Elantra
My car is full of gas yet the gauge keeps going up and down. One minute it shows it's full and then it drops down to the empty and the orange light starts dinging and it reads empty. In a 20 mile drive it...
I would start by having someone replace the sender unit in the fuel tank. This is simply a float in the gas tank which rides on the top of the gas and is connected to a variable resistor. As the gas is consumed, the float sinks moving the variable resistor and that sends a signal to the gas gauge reflecting the lower fuel level in the tank.
It is not uncommon for the floats to develop a leak, and/or to fail completely. It is not going to be cheap to remove the tank and replace the sender, so consider having the fuel pump replaced at the same time so as to avoid paying that labor cost again. The fuel pump is right next to the sender.
Apr 08, 2011 | Chevrolet Malibu Cars & Trucks
Coleman heater model 5445c700 propane camp heater wont light. It did work fine. When I hold the knob in the light position you can hear gas but it barely ignites then goes out. I've tried new gas and...
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Feb 07, 2011 | Coleman Heating & Cooling
Gas Not Flowing
Try this. Turn tank off, open all three burners for a minute or 2. Close burners. Open tank very slowly. Open primary burner, (usually the front burner) and try to relight. Should work, but if not check that valve is secured to tank and check for leaks with soapy water.
May 02, 2010 | Weber Genesis Gold B Premium Grill
When the gas tank is full the gas gauge shows as empty. When the gas tank is empty the gas gauge shows as full.
Well that tells me that someone installed the wrong fuel level sensor. Your going to have to drop the tank and pull the pump and float assymbly out. Then go to a parts store and get a sending unit that has the opposite resistance of that sending unit. Just wait until the tank is empty so its a lot lighter. You can call the parts store or go down and see if there is multiple sending units. The sending units work by resistance, when the tank is full the float moves up and turns a wheel in the sending unit, which either removes or increases the resistance causing the gauge to lower. The sending units either give full resistance at full or no resistance at full and then changes as the level goes down until it does the opposite at empty.
Jul 17, 2009 | 1999 Chevrolet Cavalier
Weber Q Grill Logo
352 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
