Question about LaCie d2 (300769) 200 GB Hard Drive
Lacie D2 Triple Interface wont mount or power up,
Lacie D2 500GB Triple Interface wont mount or power up, no blue light. The Power cable is fine with other drives, so the problem is with the enclosure, how can i remove the hard drive form the enclosure?  I removed the back panel but the enclosure is not removable.
  • 158 Answers
SOURCE: enclosure replacement Lacie Porche 250
Rock 5.25" USB 2.0 & Firewire Enclosure Like the HD506, the Rock 5.25" is also the bigger "brother" of the Rock 3.5" enclosure we sell but this version has the benefit of support your CD and DVD reader/writers and its got a built in fan as well. try this model of enclosure it depends on hdd connection you could go for a diffirent model hope this has helped you
Posted on Aug 14, 2007
SOURCE: lacie d2 external drive
what are your recommended enclosure options for the d2?
Posted on Dec 31, 2007
  • 242 Answers
SOURCE: How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Posted on Mar 31, 2008
SOURCE: I have a triple interface
Please provide the method of connection to the computer.
Posted on Aug 04, 2009
  • 60 Answers
SOURCE: Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Posted on Dec 25, 2009
I have an old LaCie d2 160GB Hard Drive Extreme with Triple Interface (circa 2005)... I have lost my power cord and I can't seem to be able to find one online to purchase...Does anyone know where I can...
your drive can be used with any D2 or Big Disk power supply as well as some LaCie Porsche power supplies (you need to make sure the connector is the same).
Searching for LaCie Power supply on eBay will give you a few hits that match your needs.
Regards,
Jan 10, 2011 | LaCie (300740) 160 GB Hard Drive
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Blu light flashing
This is most probably a faulty power cable, a common fault on La Cie apparently. Another cable got my disk working fine!
Nov 12, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 (300769) 200 GB Hard Drive Logo
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
