Question about Garden
Blades keep spinning out on Flymo
The blades keep spinning out of the circular disc on the underside of my Flymo Compact 30. I can't even use it as its happening as soon as I start the blades spinning.
  • Anonymous Mar 23, 2014
    Using the spanner we are trying to get old blade off but the nut is on too tight. Any suggestions
  • 420 Answers
Replace the disc.
Posted on Aug 28, 2009
Where can we buy replacement blades?
Circular Saw Blades from Freud Sold Online - Tools Plus
www.tools-plus.com/freud-circular-saw-blades.html
Saw Blades for Less at Tools-Plus.com. Free Shipping on 1000's of Products.
Circular Saw Blades, ALL Sizes, ALL Brands Sold Online ...
www.tools-plus.com/supplies-power-tool-blades-circular-saw.html
Circular Saw Blades for Less at Tools-Plus.com. ... Shop with confidence knowing that Tools-Plus.com is an Authorized Internet Retailer. 3-3/8" Circular Saw Blades .... Saws and Replacement Blades · Automotive Hand Tools and Equipment ...
Nov 02, 2015 | Saws
Why is my flymo 360 eg not collecting the grass
If you have changed blades or have low lift blades this will be the problem. For good grass collection you should have high lift blades
Apr 30, 2014 | Garden
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
Bolt that holds blade well not loosen what is the correct direction to loosen bolt
Remember that on a circular saw, the bolts are typically left-handed thread so it is the opposite of a typical bolt. This is because the blade spins to the right so if a normal bolt was used it would loosen as the saw operates.
Jul 19, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Jul 23, 2010 | Garden
Changing the blade,the bolt just keeps spinning either direction
sounds like its striped. may be a clockwise thread or reverse thread. try to pry the bolt up while turning
May 24, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Can't tighten the blade- it spins
Use a round shaft screwdriver place between the blade teeth to prevent it from turning.
Mar 04, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Can the blade height be adjusted on the flymo 300 compact?
the blade shape can not be changed they are heat treated and if bent they will break, the only way to change the blade height is by changing the blade adapter.
Apr 05, 2009 | Garden
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
405 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
