Question about Microsoft Xbox 360 Console
When i insert the discs it fails to read and says open disc
When i insert the discs it sounds like its trying to read it but then it says open disc
  • 767 Answers
Two thing fail on the drive that cause open tray (no disk) problem.
1 the laser is weak or dead . easy to change out .
repair cost about 80.00 if D.I.Y 30.00
The spindle motor fails , little more work.
You gotta swap the pc board from the old drive to
the new one 90.00 -100.00 if D.I.Y. about 50.00
Posted on Jul 01, 2009
  • 67 Answers
Whip down the disc to make sure its clean then if it doesnt work the laser trying to read it is broken
The disc player suddenly stops playing and says no disc even if there is disc on the shelf
Your disc player has a "lens or eye" that reads the electronic signal from your disc and transform that signal into a video image and audio sound. The reason why it stops playing and says there's no disc inside is because it fails to read the signal. The lens or eye may have acquired dirt that's blocking the signal. Try to open your disc player and locate the lens located on the center of the rotating disc holder. It is very easy to locate because it is directly under the disc. It is round, very small and made of glass. Get a cotton ear bud or just a small piece of cotton, moisten it with alcohol, or nail polish remover then wipe the lens. By doing it, you are removing the dirt that may have accumulated while you were using your disc player. It is highly advisable that you switch on all your electronic gadgets at least twice a week even if you're not using them. By doing this, you are preventing your electronic devices from acquiring moisture due to heat/coldness in the environment.
Another possibility, the format of the disc that you inserted (mp3, mp4, blueray, dvd) is not compatible with your player and therefore your player was not able to decode/read the signal.
Jul 23, 2011 | JVC Audio Players & Recorders
Hi! I inserted a burned dvd r into my Mac but it's not reading it. The message You've inserted a blank CD pops out. I tried using a PC but it can't open it either, it says there's an error...
there are a few reasons why
1.) the formatting of the disk may be formatter for a PC and NOT a MAC
2.) after burning, this dvd was never "closed"
3.) You burned a coaster
good luck
Jun 06, 2011 | Computers & Internet
INSERT DISC PLAYER STARTS TO READ,AFTER A READING FOR A MIN,SCREEN READS INSERT DISC?
The disc drive is not reading and so after it tries on for some time the drive does not detect and so fails to read. You can try and clean the optical lens unit manually using an ear bud with delicate wipes on the lens eye. If this wont change the error then the optical unit is faulty and will need a change.
Apr 12, 2011 | Cyberhome CH-LDV1010RS Portable DVD Player
Hi. I have a Sony MZ-N710 Mini-Disc Walkman which wont read discs and also does not charge. If power is connected via the charging station or directly, or via external battery adapter the spinning disc...
Possible that the optical head unit has failed in your walkman and might need a replacement. It will be adviceable to seek the cost factor of a replacement unit of Sony that might turn out expensive ... to the entire cost of the set.
So unless the optical head reads there is no data transfer or processing.
Nov 03, 2010 | Sony MZ-DH710 Personal MiniDisc Player
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
When I put the disc in, a window pops up that says put in the correct disc. but it is the only one I own
Sounds like your computer is having difficulty reading the disc.
Try ejecting the disc and re-inserting when this message pops up.
If this fails,try cleaning the disc. Most game stores or video stores will buff it for you for a small fee.
If this fails as well,then it could be your settings.
Does your computer have all the needed requirements to run the game? Is it compatible?
If your answers are yes,then it could be that the disc is bad...try different settings,and the aforementioned ideas and if these all fail I would try and return the disc.
Oct 04, 2009 | Electronic Arts The Sims: Life Stories for...
Model #GWA-4164B DVD Writer does not recognize any disc Cd or DVD. computer sees the drive when you install a DVD it tries to read and fails . Try to explore it indicates please insert a disc. Firmware is...
It sounds as if the disc drive laser has died, when they burn out they will not recognize any disc inserted. fortunatly a replacement drive is relativly inexpensive to replace.
Aug 24, 2009 | Hitachi Computers & Internet
Won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | Aiwa NSX-A115 Shelf System
Microsoft Xbox 360 Console Logo
71 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
