Tasco Luminova 40060660  Telescope
Problem for Tasco Luminova 40060660 (660 x 60mm) Telescope
Just came into a used tasco 302048 . Everything is upside down!!!
By rlstump on Jul 01, 2009
tasco telescope 302048
I am a rookie. Why am I seeing everything upside down?
Solution #1
posted on Jul 03, 2009
Somewhat Helpful)
mcneb
Rank: Guru
Rating: 86%, 177 votes
A telescope sees that way. you have to have a corrective lens to right the view. Its a physics thing about how light goes thru a lens and at the lens flips over upside down, you need another neutral lens to flip it right side up again. If you got the entire kit try another lens till you find the corrective lens.
Was this helpful?
Yes
No
Solution #2
posted on Oct 23, 2009
Not Rated)
cavefrog
Rank: Apprentice
Rating: 0%, 0 votes
the scope is made for both terrestrial viewing and astronomical. In order to see terrestrially upright, you need an inverting STAR DIAGONAL. The eyepiece will do nothing for inverting the image. you might have 2 diagonals in the kit that came wih the scope. the diagonal is the part that fits into the scope. then you place the eyepiece in the diagonal. if you have 2 diagonals , one is a 90 degree angle,(astronomical) and one is a 45 degree angle, (terrestrial). the eyepieces change the magnification of the image. the bigger the number (9mm, 20mm, 26mm,) the smaller the image. the smaller the number , the bigger the image gets. the number is inverse of the image. Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Tasco Luminova 40060660
Questions and Unsolved Problems for Tasco Luminova 40060660
Do you recommend Tasco Luminova 40060660 (660 x 60mm) Telescope?
Answer
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Answer
What is the voltage and battery number for a Tasco red dot Propoint PDP2
Answer
What is the voltage and number of the battery for a Tasco red dot Propoint PDP2
Answer
I purchased a bushnell 78-5500 and i don't have a manual and i can't mount it How can i mount it or... (More)
Answer
got a new scope, put it together and can't see anything,yes i took the lens cap off
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tasco Luminova 40060660 ...:
Top Telescope Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Telescope Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
