Question about Neff 24 in. S5543X2 Built-in Dishwasher
Food debris on dishes
Help! Recently we noticed that when the cycle is over the dishes are not clean. Food debris seem to be stuck to several a lot of the "Clean" crockery. We use multi-seeded bread and cereals and the debris is manily these seeds. I have pulled out the grill at the bottom of the dishwasher and cleaned the trap. I also used dishwasher cleaning cubes and we are being very careful in rinsing dishes prior to placing in the machine. However, we still are experiencing the problem. It seems that there is food debris trapped elswhere in the machine which is then being pumped out during the cycle. The debris sticks to the crockery and becomes baked on by the heat. Hope someone can help us with this problem as we are now having to hand dish wash!!!
  • 1 more comment
  • lfrig Dec 02, 2007
    we are having exactly the same problem - cleaned all the obvious parts (Arms, filters, waste pump chamber), but there seems to be some dirt trapped somewhere, which gets pumped into the machine. Help!!
  • sharv May 13, 2008
    Have the same problem. I have run the machine with the door open and have noticed that the two spinning spray arms are not moving. The water pressure coming from them does not seem very powerful?
  • hdockham
    hdockham May 13, 2013
    i'm having the same issue pulled the food trap and the trap below that in the trap i have a resonation of water just stting in the trap how do i clean and prevent this as of right now i use some bleach and mister plumber to clean and unclog the drain what else can i do to complete this issue have seven kids need to get this done soon!!!!!!
    Problem Solver:
  • 19 Answers
Try running the dish washer a couple of times with out any dishes and see what happens.
Posted on Nov 09, 2007
Ge dishwasher not cleaning dishes and leaving debris behind
check for corrosion or debris in the water jets clean if necessary
Mar 11, 2012 | Dishwashers
I get major residue and (scum and white spots) on my dishes, along with food being sprayed all over them. They seem to come out more dirty than when I put them in!!! I end up washing dishes in the...
Hello, W/D here.
There are cleaning products out there that "sort of" work, some better than others, but here's how to get it cleaning like new:
1. Clean the spray arms nozzles and slots. If the spray arm can be removed, take it off, and clean it over the sink. I use a regular paper clip, bent into an "L" shape, and use it like a rake to pull debris out of the slots on the tips of the spray arms, and poke any stuck debris back through the nozzle holes, then backwash the nozzles and slots with the water from the faucets, back towards the opening where the spray arm was attached. Take your time; it's far better to do it right, than to have to do it over. For those spray arms that cannot be removed, use the paperclip to rake out as much debris as possible, but realize that they will probably need to be cleaned over the period of several cycles to get it all out. Same for the nozzle holes.
2. Add to the bottom of the dishwasher, spreading evenly and in this exact order:
1/2 cup of salt
1 cup of baking soda
2 cups of white vinegar
The mixture will foam up and clean your screens and sump of debris, soap scum and food particles.
When the foaming has ceased, add 2 cups of bleach to the washer sump. Run the water source closest to the dishwasher water supply line (usually the kitchen sink) until it is as hot as it can get, then start the washer on it's sanitary cycle.
The best washing advise for those daily runs is to always heat the water by running the sink water first, and to use a good rinse aid. Lastly, I recommend that folks use the least amount of detergent possible while still getting the dishes clean. We presently use about 25% of the recommended amount; a little in the cup, and a sprinkle on the door, heat the water up, and off we go. The dry detergent is abrasive and often contributes to cloudiness seen on the dishes and mostly glassware. Cut your detergent to 50% to start with, and adjust up or down from there, until you have the right amount for the quality of water in your area, and the demands of your washer.
Here's hoping that you find this useful.
Best regards, --W/D-- Please take the time to rate our solutions so that we may continue to improve in helping others. Thanks.
Feb 23, 2011 | Danby DDW2406 Stainless Steel Built-in...
No matter what brand of rinse aid I use, there's always a white film on glassware, dishes, etc. Is there something wrong with the dishwasher?What could be the problem?
Hello, W/D here.
We've had the same problem, and here's what we did to solve it.
Clean the dishwasher as best as possible. Place t cups of vinegar in the bottom of the tub, and run a hot cycle. The vinegar helps kill and remove the scum that can build up in the sump of the tub. If the spray arms are clogged, you can remove the debris with a paperclip or toothpick. (Check and do that regularly anyway).
Cut back on the detergent as far as you can, while still getting the dishes clean. I know this sounds a bit odd, but the amount of recommended soap is based on the dirtiest dishes, and the worst water possible. We rinse the major food particles off of our dishes before loading, so dried on food stuffs isn't an issue. We have cut our detergent to about 25% of the recommended amount, and the dishes still get very clean. We put a sprinkle on the door, a sprinkle in the dispenser cup, and close it up.
The detergent itself is abrasive, and can leave deposits on the dishes, most noticeably on the glassware. Cutting the amount of detergent, and using a good drying agent helps a lot.
Over a period of several cycles, the quality of the wash will improve. Don't expect to get to 25% of the amount of detergent right away. Cut it to 50% to start with, and adjust the amount based on your own observations.
Hope that this helped you. Best regards, --W/D--
Feb 10, 2011 | Frigidaire FGHD2433K 24 in Builtin...
After running our dishes through a wash cycle we noticed there was still a lot of food stuck on the plates & glasses etc. We cleaned out the trap but due to the murky water in the well, we also pulled...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Oct 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Aug 22, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwasher kenmore 16789
It sounds like your wash pump impeller might be clogged. The first symptom of this problem is poor cleaning capabilities and food left on dishes. You will need to remove the spray arm assembly to access the reservoir below the spray arm. More than likely, you will find debris clogging the the wash pump impeller area. As a general rule of thumb, you should not put anything into dishwasher that still has to be chewed. You don't have to prewash your dishes, just scrape them real well. Most detergents still need to oils and residue from food to activate the cleaning agents. If you prewash, you simply defeat this purpose. Some things that should NOT go into a dishwasher are lemon seeds, orange seeds, pistachio seeds, popcorn kernels, chunks of meat, bacon, tooth picks, chicken bones, match sticks, bottle cap liners, jar labels, etc. These are a small example of SOME of the things I have personally found in the wash pump. It doesn't take much to clog the pump, and the chopper assembly is not to be considered a disposal. I hope this helps you. Let me know if you need any further assistance.
Jul 25, 2007 | Kenmore 16879 Built-in Dishwasher
Not cleaning properly. Not Draining properly?
Don't Buy GE :)
pump may me clogged does it drain, can you hear water spray. is water filling into unit on start up? I had to take pump of bottom of mine had piece of tooth pick jammed in impeller + GE just stinks anyway. I will never buy again
Jul 04, 2007 | GE 24 in. GLD5860LSS Stainless Still...
Neff 24 in. S5543X2 Built-in Dishwasher Logo
628 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
