Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
What is replacement for mcz3001d? - Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Qualia 004 doesnt work i cannot turn it on.
Hi the problem is in the board GB, open the projector and find the GB Board an change only one component, the MCZ3001D! The board have two McZ3001D, only change the side position!
Apr 18, 2012 | Sony QUALIA 004 Multimedia Projector
I have a Sony Vega KV 32HS420 it will not come on and bliniks 6 times. what is up?
Try replacing IC8002 and IC6501 (MCZ3001D).
Hope this helps.
Apr 07, 2011 | Televison & Video
When I turn the tv on, i hear a click and then nothing. the standby/timer light comes on then goes off.
when it flashes 6 times,there is a ic replacement nessesairy the ic is named mcz3001d and is locatted near the flybacktransformer.mostly when you heat it up,it will work.
Apr 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The standby light keeps blinking and tv won't turn on
when it blinks 6 times,you have to replace an ic.
its named mcz3001d and is located near the flyback transformer.when you heat it up ,the tv will work.
so you can check if that is the problem
Apr 07, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
My tv turn red and blink 13 time
Hi ,
I had same problem my TV. Replaced IC8002 on the 'D' board.
This is what we did:
1.Bought 2 x MCZ3001D from WES components in Ashfield Sydney Australia for $11.20 (each).
2.Friend had an 18 pin machine spun socket (not the crappy ones on EBAY).
3.Took back off TV
4.Put the 'D' board in service position
5.Noted which way IC8002 chip sat (Where position 1 is), also noted which 2 legs are not soldered.
6.Cut the black plastic that was covering this chip underneath (where D board screws into) as this is easier than removing the 'D' board.
7.De-soldered the IC8002 chip with a proper de-soldering iron. These are expensive though.
8.Soldered in the 18 pin socket.
9. Set the chip into the socket.
10.Tested TV, worked fine.
11. Put it all back together, plugged in Tivo, DVD etc etc etc and all bloody good stuff.
12. I now also have a spare MCZ3001D which is taped to the back of the TV for future replacement, which is now easier since its now in a socket.
Aug 12, 2009 | Sony KDL-40XBR4 40 in. LCD HDTV
Sony kv-32fq86e 16 blinks
If red led blinks continously , please check horizontal o/p or EHT screen control reduce and check for power on
sam
Apr 18, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony kv40xbr800 wont turn on, standby light flashes 7 times
Research replacement of MCZ3001D IC's......Not a repair for
novice, senior tech only...................T.
Nov 21, 2007 | Sony KV-36FS16 36" TV
Kv40xbr800 standby flashes 7 times, sony 40"
Research replacement of MCZ3001D IC's.......senior tech only.
Not a repair for novice....................T.
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
219 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
