Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
My dishwasher KUDi01IL is having trouble with the electronics...only the cancel button will work. The other buttons are no longer lit, but occasionally I can get the "normal" wash button to light..however, the machine will not start. Called technical support last night, tried unplugging and plugging back in due to possible power surge or storms....it did not help. Please advise.
  • 10,515 Answers
As we are not there, we can make some intelligent guess. This is a common problem in Dishwasher.There might be million of reasons for the same and to be frank you would agree. Let me put down some main reasons which i have found ;-
1. There is usually a Thermal Fuse mounted on the Control Board ( On most of the models ). If that Fuse is at fault or might be due to open connection, you might see buttons lit intermittently or very rare.
2. Bad Control Panel - Main reason for your problem.
90% of people who suffer from above mentioned problems have Bad Control Panel. Check and if at fault, get it replaced or repaired ( Better replace it ).
Note down the part number. Either look for online vendors like ebay and so and purchase and fix it yourself or call a tech to replace that.
Note - Always confirm the fault before ordering any element.
Hope i helped you.
DO RATE THE SOLUTION.
Thanks for using "Fixya".
Posted on Jul 01, 2009
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Most buttons on the control panel do not work. The only 3 working buttons are high temp wash (htw), sani rinse, and heated dry (hd). We tried resetting the console by hitting the sequence of htw, hd,...
Shut power off to dishwasher for about 5 minutes and see if control panel will reset. This sometimes helps. If problem is still there you may have a bad control board.
Apr 03, 2015 | Dishwashers
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a KUD101FL533 Kitchenaid dishwasher. The other buttons light up and the cancel button works, but when I hit "start" nothing happens. From what I have read, it may be the control panel. Do...
Hello, Christi,
What i would try first is see if perhaps the ribbon cable has come loose from the control panel the touch pad is separate from the control board and its entirely possible that its bad and not the control panel.Also i would surly want to check to door switch as well since they are more common problem than either the touch pad or control board ..to me its sounds like possibly the door switch is the problem since it thinks the door is open and wont allow it to start since the door switch thinks its open .
Please respond if you should need further assistance.
GENE
Oct 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Is there a reset button on the dishwasher? if so, where?
Not sure what type of reset you are after. Is the dishwasher not responding to any panel switches.
Is the keypad locked, i.e., is the control lock light on? Then press Energy Saver Dry button for 4-5 secs.
Are some lights flashing and dishwasher will not start? Have you tried to turn mains power off and back on?
If you think the controller needs a reset, you could try this sequence of keys within 7-8 secs.
hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry.
If the reset sequence has worked correctly, then all lights should light up. Press Cancel to exit from reset mode. I am assuming you have a users manual. If not then download from here.
Please rate the solution if it helps your problem otherwise post a comment
Feb 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
My Kitchenaid dishwasher is acting up. Everything else works but when you push the start button it will not start. model # KUDM01TJBT0
What happens when you try to start ?Do you get any lights blinking?Do your hear any motor turning ?What happens?
Sep 09, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
-high temp wash -heated dry -high temp wash -heated dry
After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
Thank you!
May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Normal cycle button blinking, cannot start new wash cycle
Press Heated Dry, Normal, Heated Dry, Normal buttons in sequence within 6 seconds to reset control. Could also be locked. Press and holding the air dry button for four seconds.
Nov 18, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
HEATING ELEMENT
hi follow the manual: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8574093.pdf if it dosent work then as you mentioned the heating unit is bad you can replace it by yourself by buying it and insalling it its easy as installing a lamp but you can call for help (number in the manual) good luck
Mar 21, 2006 | KitchenAid 24 in. KUDI01IL - Multiple...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
206 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
