Question about Electronics - Others
Onan 4kw Emerald I generator will not crank
I bought a 1987 motorhome with an onan generator in it.... the guy told me it ran last year fine and this year they went to start and it would not crank. He replaced the mother board($130) but it did not fix the problem. Batteries are good...I have tried starting when plugged into house...gas tank is half full in camper. It does not make a sound when I push the start on the generator or remote start. Batteries do not show a load when start button is pushed. Any ideas? Generator ''looks'' like it is in good condition.
Thanks in advance
    President:
  • 1,723 Answers
The gen. is not the problem, the engine start circuit is not functioning. You need to look at the starter solenoid and starter.
Posted on Jul 05, 2009
Onan generator cranks then wines no start i have a onan generator in my motorhome it stop running now when i try to start in it turns over but does not run what should i9 cheack
check oil level in the sump
if the oil level is correct check for a problem oil level sensor circuit
it is there to stop the engine when the oil level reaches critical level
Dec 12, 2016 | Electrical Supplies
Rv Motorhome Onan Emerald III Runs fine no power out put
There is a breaker at the gen. usually near the start switch. When off no power from gen. to house.
Oct 31, 2016 | Electrical Supplies
My generator will turn over but wont start
Our motorhome Onan 5000 Marquis generator will turn over and try to start but fails everytime we test. We have primed, gas and oil are fine and we have new spark plugs. We also changed the gas filter on the generator. Any suggestion? Thanks, Loretta
Mar 30, 2014 | Watts Onan Portable Generator - 4000 ,...
Onan 4000 not charging battery
Some Onan 4KW do not have auxiliary battery charge windings and rectifier. Are you sure you have one? If not you will need and external charger
Oct 11, 2013 | Onan Electrical Supplies
My onan emerald 1 genset is not transfering charge to the battery
Assuming your generator has the battery charger option?
Measure the battery voltage at the battery lead in the generator, without the unit running, or the motorhome ignition on. It should read approx 12V after the unit has been sitting a while. Then start the generator, it should rise to approx 13.8 with a good battery. If it does not then the stator windings and charge rectifier in the generator should be checked. If the voltage is 13.8 approx with the generator then you problem lies further upstream, and possibly with an isolation solenoid. If you generator does not have a battery charge winding/option then charging comes from the line voltage via a motorhomes inverter, check the inverter.
Sep 08, 2012 | Onan RV QG, 2500W GenSet, LP Gas
I have a 1984 winnebago motrhome with a 6500nh rv onan generato runs getting power on the line but none in the motorhome
Hooked in to motorhome via automatic switchover, or does the power plug of motorhome have to be plugged in to receptacle at or near generator?
Mar 15, 2010 | Watts Onan Portable Generator - 5000 ,...
RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Aug 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Looking for an ONAN Emerald I GenSet generator manual
I have an account in the Buffalo NY area .. they can help you with this .. call 716-668-2666 after 9:00am EST tomorrow (sat)
Apr 03, 2009 | 1988 Chevrolet C3500
Electronics - Others Logo
454 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
